NikonClub.it Community > PRODOTTI NIKON > NIKON PRODUCTS FAN CLUB
Pagine: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603
inquisitore
QUOTE(topdown @ Nov 21 2012, 02:13 PM) *
......dove le mucche si fermano a bere...
micweb
dopo una lunga assenza ( motivi vari ) ecco uno scatto serale
Visualizza sul GALLERY : 508.3 KB
fabio aliprandi
QUOTE(micweb @ Nov 21 2012, 03:54 PM) *
Complimenti..bella profondità!!
lucianote
Grazie Raffaele
Ora sono anchio un possessore della D7000, ho appena caricato la batteria, e ho provato a scattare un po' x vedere se tutto funziona,ed e' una figata. Adesso mi andro a leggere FOTOGRAFARE_CON_D7000.doc , Ti ringrazio ancora Raffaele, e anche te Adriano se avro' bisogno so sempre su chi contare.
luciano
micweb
altro contributo per le vie di ferrara.
Visualizza sul GALLERY : 494.7 KB
bat21
QUOTE(lucianote @ Nov 21 2012, 06:27 PM) *
Grazie Raffaele
luciano
Benvenuto da Bologna!
Bologna - Panorama con le Due Torri e la cupola di Santa Maria della Vita di Massimo Battesini, su Flickr
Nikorra
QUOTE(Fabio Aliprandi @ Nov 20 2012, 05:31 PM) *
Uno stralcio di Milano..
Visualizza sul GALLERY : 1.5 MB
QUOTE(Fabio Aliprandi @ Nov 21 2012, 01:31 PM) *
Battery grip arrivato targato Meike.
Le ghiere sono "normali" come apertura/chiusura dello stesso corpo macchina..
Una domanda però: la rotellina per fissarla al corpo macchina tiene bene, ma quando lo fisso bene al corpo macchina la rotellina fa un piccolo giochetto sopra/sotto..è normale? Il fissaggio è comunque perfetto, ma se per esempio tocco la rotellina fa rumore.
Vi dico questo perchè con il mio vecchio BG della D3100 il fissaggio era perfetto e la rotellina rimaneva fissa senza nessun minimo gioco sopra/sotto.
È normale?
Tranquillo, assolutamente normale.
fabio aliprandi
QUOTE(Nikorra @ Nov 22 2012, 01:41 PM) *
Maledetta correzione dell'iPad.
Volevo dire un "passo" di Milano.
In senso abbastanza allegorico del termine.
lucianote
Ragazzi Buonasera
una curiosita': quando si va' a rivedere una foto (in play) scattata in macchina, come si fa ad eliminare le informazioni che sono presenti sotto la foto nel monitor della macchina (cioe' il numero della prima scheda, la sigla della D7000,il n.nef, la data e l'ora, i raw ,e la risoluzione)- nella d5100 bastava premere in joystik varie volte e sparivano. qui sembra imbossibile. speriamo che si possano togliere. Comunque e' abbastanza complicata sta' 7000, e anche bella pesante.Forse era meglio se mi prendevo una D90 nuova meno complicata, Scherzo naturalmente .
luciano
walter lupino
QUOTE(lucianote @ Nov 22 2012, 08:17 PM) *
una curiosita': .....
Semplice: non puoi cancellare il contenuto in basso (che varia a seconda delle opzioni di visualizzazione scelte) wink.gif
micweb
Ragazzi Buonasera
luciano
basta pigiare in su il joestick dove c'è il simbolo OK tante volte fino alla non visione. ma i dati non si cancellano. si nascondono
walter lupino
QUOTE(micweb @ Nov 22 2012, 10:38 PM) *
No, le due righe in basso non le nascondi.
MarcoDomenicoMuggianu
Ragazzi Buonasera
luciano
Credo che sia una questione di proporzioni e dipenda dal fatto che le misure altezza larghezza dell'immagine prodotta dalla reflex opportunamente ridotte sono diverse da quelle del monitor ( il monitor a parità di larghezza ha un altezza maggiore), e questo proprio per poter visualizzare sotto l'immagine prodotta le due righe di informazioni, se vuoi avere la foto a tutto schermo ingrandisci la foto col tasto + ma ti accorgerai che perderai parte dell'immagine (in larghezza). Se la D7k potesse visualizzare ciò che chiedi dovrebbe per forza deformare l'immagine blink.gif ... prova ad immaginare se volessi visualizzare a tutto schermo un immagine rettangolare dentro schermo quadrato cerotto.gif .
micweb
QUOTE(walter lupino @ Nov 22 2012, 11:46 PM) *
si si. hai ragione. infatti io credevo si parlasse del riquadro che appare sovrapposto all'immagine, fermo restando che le informazioni base in alto a dx il nr. scatto, e in basso le informazioni circa la scheda utilizzata, il tipo del file ecc. ecc.
micweb
sempre ferrara in bianco e nero.
Visualizza sul GALLERY : 800.4 KB
Giacomo.terra
Salve amici!
Comunque un piccolo saluto, per dirvi che domani inauguro la mia prima mostra, con tutte foto fatte con la D7000...quindi un piccolo pezzo di club domani inaugura grazie al gioiellino...
Un saluto!
igorphoto
Salve a tutti perdonate l'intromissione ma mi chiedevo se con gli ultimi esemplari di D7000 avessero corretto il "problema" della sovraesposizione che si parla in molti thread anche esteri.
magari con l'ultimo firmware...
grazie a chi vorrà aiutarmi
fabio aliprandi
Vi posto questa foto fatta al museo del '900 a Milano.
Le altre foto le trovate in "Primi Passi".
Giuro che questo "quadro" mi ha fatto prendere malissimo hahaha.
inquisitore
QUOTE(Orbiter 3 @ Nov 23 2012, 06:19 PM) *
Mah... a me non risulta, ma sicuramente non mi sono letto tutto lo scibile umano sulla D7000 proposto dalla rete mondiale.
Semmai posso dirti che tende ad esporre a DX ma volutamente (senno avrebbero rilasciato un fix via sw)... e poi voglio dire con quasi 14ev di dinamica e nef a 14 bit... mi sta più che bene che esponga a DX... (il motivo è oramai ben noto... ) ma da qua a ritenerlo un problema ce ne passa.
Questo secondo la mia modesta opionione.
ciao!
walter lupino
Nessun problema di sovraesposizione sulla mia (che ha 18 mesi di vita).
cassinet
anche per me il "problema" della sovraesposizione con la D7000 non è mai esistito, semplicemente ha un sistema Matrix che funziona diversamente rispetto ad altre nikon e bisogna prenderci la mano e impararlo ad usare bene.
igorphoto
grazie a tutti per le info...continuo a guardarmi le vs. splendide foto
Igor
atropo
Davvero bella, molto ben esposta. posso chiederti che tipo di bilanciamento del bianco hai usato?
grazianonikon
QUOTE(Giacomo.terra @ Nov 23 2012, 02:23 PM) *
Salve amici!
Un saluto!
conoscendo le tue foto,sarà un successo,comunque qualche foto della tua galleria poi, magari la posti,per noi che siamo lontani.
in bocca al lupo Giacomo,io ti seguo sempre,nel forum della D700,dalle tue foto ho imparato tantissimo.
Auguri
Graziano
QUOTE(inquisitore @ Nov 23 2012, 07:13 PM) *
ciao!
orco
Salve amici!
Un saluto!
Bella Giacomo!! Sono proprio contento di leggerti e soprattutto di leggere quanto hai scritto!! Sicuramente sarà un successo!! wink.gif
Adriano
ciao!
Tua opinione un par di ciufoli!! E' sacrosanta verità e, aggiungerei, inconfutabile!! messicano.gif
Mi stupisco che girino ancora ste leggende metropolitane, ma magari erano semplicemente datate le pagine lette da Orbiter! wink.gif
Adriano
micweb
QUOTE(atropo @ Nov 23 2012, 09:09 PM) *
grazie. il bilanciamento del bianco era su automatico.
inquisitore
D7000 + Tokina 11-16
Visualizza sul GALLERY : 872.7 KB
fabio aliprandi
QUOTE(inquisitore @ Nov 24 2012, 10:29 AM) *
Bell'HDR, o almeno presumo.
Peccato per l'antenna tagliata in alto a sinistra.
Direi piuttosto "Peccato per l'antenna", forse sarebbe stato meglio eliminarla in PP, anche se ripresa per intero.
fabio aliprandi
QUOTE(monteoro @ Nov 24 2012, 12:27 PM) *
Non è ripresa per intero, a meno che l'intero non è compreso al margine dello scatto.
inquisitore
QUOTE(fabio aliprandi @ Nov 24 2012, 12:06 PM) *
Grazie.
Non è un hdr, ho esposto x il cielo e poi tirato su ombre da ACR, anche se noto solo adesso un pò di alone intorno al tetto... mi era scappato.
L'antenna di cui parlate è un cavo elettrico.
Lo avrei clonato, è piccolo ma come elemento di disturbo influisce.
@ Fabio - in effetti il mio post così suscita qualche dubbio, a volte non premere il tasto SHIFT cambia il senso alla frase; la frase giusta sarebbe:
Direi piuttosto "Peccato per l'antenna", forse sarebbe stato meglio eliminarla in PP; anche se ripresa per intero.
orco
QUOTE(inquisitore @ Nov 24 2012, 02:06 PM) *
Grazie.
Effettivamente l'alone attorno al tetto si nota, comunque è efficacie la PP, parecchio. Meno male che hai specificato che era un cavo elettrico, altrimenti avoja a cercà l'antenna!! biggrin.gif
Adriano
inquisitore
QUOTE(orco @ Nov 24 2012, 03:24 PM) *
Adriano
Grazie.
Altro scatto di qualche ora fa..
Visualizza sul GALLERY : 856.6 KB
Adorabile secondo me la distorsione prospettica della porta (voluta) e il verde "interno"...
Sempre Tokina 11-16
gioton
Io ho acquistato una delle primissime macchine arrivate in Italia, ho seguito questo club dal primo giorno e non ricordo che ci siano mai state delle motivate lamentele per sovresposizione. Ovviamente una macchina come la D7000, che non è una compattina, chiede di essere usata con almeno un po' di competenza. Ti consiglio di leggere pag.8 di "Fotografare con D7000".
Giorgio
orco
QUOTE(inquisitore @ Nov 24 2012, 03:43 PM) *
Grazie.
Sempre Tokina 11-16
Bella e concordo con te!! Mi piace tanto il dettaglio di questa lente. I fiaschi davanti al camino sembra di poterli toccare e l'alone di umidità sotto la tavella, accanto alla porta, è bellissimo. Non è un fish, ma a 11mm le immagini assumono una "rotondità globale" che si avvicina molto alla resa di una lente fish, pur mantenendo una sua lienarità.
Ovviamente la compo non è merito del tokina, quindi, ottima lente, in ottime mani!! wink.gif
Adriano
fabio aliprandi
Grazie.
Sempre Tokina 11-16
Domanda: ma la vognettatura ai lati è voluta in PP o già lo scatto ce l'aveva? Come mai?
inquisitore
QUOTE(fabio aliprandi @ Nov 24 2012, 05:54 PM) *
Messa io in pp xé mi piaceva particolarmente
fradcol
ciao ragazzi
avrei bisogno di un consiglio.. cosa portereste per un matrimonio al mio posto: 16-85 35 1.8 e 85 1,8 flash sb900.
dovrei fare qualche foto solo in chiesa, ma senza alcun impegno..
francesco
dariorubeo
Grazie.
Sempre Tokina 11-16
complimenti mi piace molto sembra un hdr ...
dariorubeo
sono uscito presto (come al solito) ma una nebbiolina persistente ed impercettibile mi ha perseguitato tanto da rendere tutti i scatti molto morbidi mettendomi in difficolta sul trovare la giusta esposizione
uno degli scatti:...........
Visualizza sul GALLERY : 468.1 KB
Giacomo.terra
QUOTE(lucito @ Nov 23 2012, 09:17 PM) *
Auguri
Graziano
QUOTE(orco @ Nov 23 2012, 09:34 PM) *
Adriano
Grazie ragazzi!
Moltissima gente all'inaugurazione, molti che neanche conoscevo quindi ottima cosa...essendo la prima mostra mi sono accorto di aver trascurato qualcosa, ma tutto si impara con il tempo e provando...
Non ho al momento foto della galleria perchè stasera non ho avuto tempo di farle, arriveranno smile.gif
megthebest
QUOTE(dariorubeo @ Nov 24 2012, 10:35 PM) *
molto buono.. alla faccia dello scatto morbido!
hai lavorato sui colori? il blu è veramente cupo e profondo...
uno scatto di ieri mattina per le campagne marchigiane:
con 16-85
megthebest
ah.. a proposito.. dopo 1 anno e 4 mesi e più di 18k scatti.. ieri sera ho pulito il sensore alla mia piccola..
5 minuti, panico inziale perchè il passaggio della prima swab umida aveva lasciato un alone, poi sistemato con una seconda swab.. ed ora mi posso dedicare alle macro.. a f/22 non ho più nemmeno l'ombra di un granello di polvere!
hUMANtORCH
Anche se non inserisco foto,seguo comunque con tanto interesse il forum...Complimenti alle nuove foto (tutte belle) ed un saluto ai nuovo possessori della D7000.Ecco una mia foto:
Visualizza sul GALLERY : 485.1 KB
* D7000/Samyang 85 f/1.4
f/4
1/250sec
100 Iso
Nitidezza:4
Contrasto:8
dariorubeo
QUOTE(megthebest @ Nov 25 2012, 02:05 PM) *
con 16-85
Grazie anche se tornando a casa non ero proprio sicuro dei risultati ad esempio ne avevo fatta una alla luna la stessa sera ma non si poteva proprio guardare un alone incredibile poi io non sono nemmeno sto fenomeno in pp comunque na toppetta ce l ho messa
AlbertoBedo
Un saluto a tutti
Visualizza sul GALLERY : 1.9 MB
dariorubeo
QUOTE(AlbertoBedo @ Nov 25 2012, 05:25 PM) *
Un saluto a tutti
ciao alberto devo dirti che questo tipo di effetti non mi piacciono in una foto pero sono gusti personali e prendili come tali
un saluto
oraziotp
Volevo condividere con il club al quale contribuisco poco, ma che frequento e leggo costantemente, un piccolo test fatto con un'ottica datata, estremamente economica, meno di 50 € sui soliti canali dell'usato,ma secondo me incredibilmente attuale e che mi permetto di consigliare, anche su D7000....
il Nikkor 50 mm Ai f/2
Visualizza sul GALLERY : 990.5 KB
fabio aliprandi
QUOTE(oraziotp @ Nov 26 2012, 12:10 AM) *
Mamma mia che nitidezza..
Cmplimenti davvero per lo scatto..!! E te lo dice uno che non ama fare foto ai fiori laugh.gif
