Pagine: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762
the_nis
Ormai sono alla frutta pure io!
Notte Giangarlo.
the_nis
Low battery!
Buonanotte!
Attilio PB
Ciao Giancarlo!
Non ti vorrei deludere, ma tutti i miei still life (e la maggior parte di quelli che ho visto fare) vengono fatti su tavolacci molto molto meno sofisticati. Io solitamente uso un tavolo di legno normalissimo appoggiato ad una parete, sulla parete c'è un listello di legno dove con quattro puntine fermo uno o due fogli di cartoncino bristol del colore e della misura necessari, il cartoncino scende dalla parete e finisce sul piano del tavolo con una curva, se è troppo corto ne aggiungo un secondo sopra senza badare troppo al punto di giunzione, prestando solo attenzione a mettere due pesetti in modo che stia fermo e non si sollevi proiettando ombre. Con un paio di flash e due pannelli di polistirolo si fa già moltissimo, il materiale che serve, flash esclusi, è roba da spendere 5 euro in totale (1 euro due fogli bristol del colore che desideri e le puntine da disegno, 3 euro due pannelli di polistirolo, avanza ancora un euro per il caffè tra la cartoleria ed il centro di bricolage).
Se proprio vuoi esagerare compra piu' pannelli di polistirolo, ottieni una luce molto ben diffusa ed avvolgente se ne disponi due a V ed in mezzo ci metti un flash diretto verso il centro della V, naturalmente il soggetto da illuminare sarà dal lato aperto della V...
Parliamo di fotografare oggetti che starebbero sul piano della valigetta, vero?
Attilio
SkZ
ciao a tutti
io nanno
doamni di nuovo a pd per prendere i certificati
danardi
QUOTE(the_nis @ Feb 13 2009, 01:21 AM) *
Ci vuole il cavalletto (anche mini per le occasioni)
vvtyise@tin.it
problemi di connessione dalle 05:00 fino ad ora! Buon pranzo a tutti!
alcarbo
Apro
Attilio PB
Buonasera Alfredo e buonasera a tutti. Martina la conoscevate, vero?
Attilio
nippokid (was here)
Mihihihiinkia Martina!!
Fammi un pò vedere!!?
Iiiihihihihiiii....
gbarbiera
Mi sembra di no un lato "B" così non si dimentica facilmente.
Attilio grazie per la risposta. Ho preso il secondo SB800 e per ora mi fermo con gli acquisti. Devo imparare bene ad usare i due flash. La dritta del cartoncino bristol e del polistirolo è ottima, li proverò visto il loro basso costo. In un negozio di ferramenta ho visto dei pannelli di plexiglas translucido se non costano troppo provo a farmi un tavolo da solo.
Posterò i primi tentativi per un vostro giudizio.
Ora a nanna altrimenti crollo sulla tastiera. Mi sa che non me ne sono accorto ma mi ha punto una mosca tze-tze e mi ha inoculato la malattia del sonno.
Notte a tutti
Attilio PB
Giancarlo, prego, il polistirolo è ottimo, la superficie non liscia offre una luce che a me piace molto, poi è facilmente gestibile, ora che sono piu' "ricco" e "attrezzato" mi capita di rimpiangerlo, prima o poi mi faccio un paio di forchettoni cinematografici per i pannelli di polistirolo e non ci penso piu'...
Nippo, ma che bell'equino che hai rintracciato :-)
danardi
QUOTE(npkd @ Feb 14 2009, 12:15 AM) *
Iiiihihihihiiii....
Simpaticissima!
the_nis
Simpaticissima... Martina!
Attilio mette una nuova barista e ... teaaak il bar si anima hmmm.gif ci sara' un nesso? Mah!!!
Ciao Nippo ti eri estraniato? Visto che due giornate spaziali (vento e gelo a parte)? Ieri si poteva andare in bici... a vela laugh.gif
Il plico su CS2 e' giunto (dovevano essere 5gg ... rolleyes.gif ). Grazie Attilio per il suggerimento, se poi non e' buono ti vengo a prendere Police.gif .
Giancarlo comincia a provare che i risultati vengon dopo.
Ciao Alcarbozzzzzzzzzz
Ciao anche a tutti gli altri.
the_nis
Io sono assolutamente incapace di fare ritratti...
http://www.repubblica.it/2006/08/gallerie/...ss-atomo/1.html
forse mi posso consolare, credo di essere in buona ( rolleyes.gif si fa per dire) compagnia.
Quante di queste foto salvate?
Attilio PB
Io di fotografie non ne salverei nessuna, in compenso un paio di bariste potrebbero andare...
Sono perso nel sito web di un distributore di materiale cinematografico..., devo chiudere quella pagina prima di un attacco di shopping compulsivo notturno che tanti danni ha già fatto in passato rolleyes.gif
Attilio
Gufopica
QUOTE(Attilio PB @ Feb 14 2009, 12:08 AM) *
Attilio
complimenti notevole!!!!!!!!!
nippokid (was here)
Io invece il danno l'ho già fatto, or ora... unsure.gif ...solo che al posto che comperare un 85 f/1.4 ho pagato l'assicurazione auto!! cerotto.gif
Ciao AlcarbozzZ!! Ciao Giancarlo!! Ciao Nis!!
Oggi è arrivato il Vertex inglese. Ottimo, soprattutto il prezzo. Ora lo stivo insieme agli altri zaini!! cerotto.gif laugh.gif
the_nis
Comprate ragazzi che bisogna tenere in piedi l'economia!!!
Io mi sono limitato ai due libri e un minimo pensierino. Voi avete pensato? Ricordartevi di fare una coccola alla vostra amata domani (che 'e oggi)! rolleyes.gif
A me l'assicurazione cade il mese prossimo, vado con 170 ore di permessi non goduti dite che li accettano? tongue.gif
Attilio PB
QUOTE(the_nis @ Feb 14 2009, 01:51 AM) *
Guarda, io ho appena trovato le forchette per i pannelli, disponibili a 15 euro l'una, mi sa che due o tre le prendo...
Devo studiare, devo studiare di piu', mi accorgo di non sapere nulla di illuminazione cinematografica (quasi nulla via...) ed invece è determinante, se non per il lavoro contingente, sicuramente per migliorare complessivamente...
Chissà un buon testo per iniziare...
Ora lo cerco.
the_nis
QUOTE(Attilio PB @ Feb 14 2009, 01:58 AM) *
Ora lo cerco.
Cosi' si fa!!!
Attilio PB
Nippo, ma con il Vertex non ci fai neppure un giro prima dello stivaggio? Io quando prendo uno zaino nuovo lo riempio tutto e ci esco unsure.gif
L'assicurazione io l'ho pagata il mese scorso, oramai mi sono quasi ripreso dallo choc.
Comunque ho capito definitivamente che la D3 mi basta e mi avanza anche per chi richiede dettaglio e risoluzione, altro che medio formato..., lasciatelo stare dov'è, semmai lo faccio in pellicola...
Faccio un giretto, va....
nippokid (was here)
Bravo Attilio!! ...mi ero dimenticato di chiedertelo, poi mi era passato di mente...
Sto appunto cercando (..meditando di cercare tongue.gif ) un libro di tecniche di illuminazione cinematografica.
Rigorosamente di impronta americana, meglio se di un direttore della fotografia.
Ma perchè dici che non usi i polistiroli? Cosa usi? I Lastolite? Io in studio ho più polistirolo che aria, in metri cubi biggrin.gif
E non potrei assolutamente farne a meno...
...non uso però i forchettoni, sono pannelli 2x1mt o 3x1mt per unire gli angoli uso l'american tape o delle "fasce" di legno forate da parte a parte con delle "viti" e "bulloni" sempre di legno.
Portabici (quelli per le ruote anteriori) o delle "squadrette" dei legno per mantenerli in piedi...
the_nis
QUOTE(Attilio PB @ Feb 14 2009, 02:07 AM) *
the_nis
Nippo ma sei proprio un artigiano della fotografia.
Pero' il flash a padella (o ciambelliera non ricordo) non me lo hai ancora spiegato..
nippokid (was here)
Ma si, scherzavo sullo stivaggio...ora me lo spupazzolo per bene per "prendergli le misure", poi lo metterò in archivio pronto per le giuste occasioni. E credo che saranno molte tutto sommato. Trovo che sia di una dimensione giusta perchè non diventi troppo pesante e per portarselo via con discreta non-chalance con un paio di corpi, tre o quattro vetri e ammennicoli, flash, meters e cagate varie...anche in bici.
nippokid (was here)
He he il padellone...l'avevo accrocchiato a mò di ring flash.
In pratica è una padella (si chiama proprio così..e la ricorda pure), ossia una parabola molto ampia, tipo padella, con un buco in mezzo dove si aggancia la torcia flash. C'è poi un riflettore (una mini-padella) davanti al bulbo che riflette il lampo sul padellone che poi lo spara sul soggetto... hmmm.gif ...cerco un'immagine di esempio va, chè non mi so spiegare...
Ecco questa è una padella, manca la contro-padella che ripara dalla luce diretta e la riflette sulla parabola...
..ora vedo se trovo altro...
nippokid (was here)
Beh, non trovo altro, comunque a prescindere dalla contropadella, avevo schermato maggiormante la luce nel centro, lasciando passare il lampo solo in un anello vicino alla massima circonferenza del padellone, facendone quindi una specie di ring, pur non potendo scattare con l'obiettivo dentro l'anello...
the_nis
Ah ecco!
L'immagine non la vedo, ma credo di aver capito.
Ma tutti sti rimbalzi non creano dei "riverberi"?
Attilio PB
Ora studio e poi ti faccio sapere, cercavo esattamente un testo di un direttore della fotografia... rolleyes.gif
Di polistirolo ne ho tanto anche io, in pannelli da 2x1 fino al 1x0,5 pero' lo uso sempre meno, ho sempre pronti dei teli riflettenti montati su telai con zampette proprie, sono 1x1,80 ed il lato B è nero, per cui li posso usare anche come bandiere, basta girare le zampine dall'altro lato, sono li' pronti e li uso, in realtà non mi piacciono tantissimo, li avevo comprati proprio per usarli come taglialuce per il flash d'effetto, poi essendo sempre montati e sul set...
Accidenti alla pigrizia.
I forchettoni invece li desidero da anni: alcuni anni fa vennero a girare in casa alcune scene di Don Matteo, fu un'esperienza affascinantissima dal punto di vista dell'illuminazione, nonostante la semplicità relativa del set, ed è da allora che desidero i forchettoni per il polistirolo...
Vabbe' provo a cercare qualcosa, poi provo anche a dormire...
Attilio
the_nis
Va beh, volevo una scusa per cambiare qualche padella ma dovro' inventare dell'altro laugh.gif
Io a nanna non provo... ci vado.
Buonanotte!
Attilio PB
Ecco una padella con relativa parabolina di serie:
Il nippo ha sostituito quella piccola al centro con una ben piu' grande...!!!
nippokid (was here)
La foto è sparita! blink.gif ...boh
No, riflessione e controriflessione non comporta "riverberi", riduce l'efficienza quello si, ma alla fine conta solo la "forma" e l'ampiezza della sorgente...in questo caso l'effetto di illuminazione è di suo "riverberata" perche viene emessa da un anello luminoso in pratica, che ha un certo impatto sul tipo di ombra prodotta ed è abbastanza differente dalle più "normali" emissioni relativamente puntiformi o diffuse...
Comunque...
P.S. E' il compleanno di Franco_
Esatto, grande Attilio!! (giusto...aproma...io gugoleggiavo..)
dario205
'notte ragazzi, come va??? Ma a proposito di esperimenti... mi parlate di foto con filtro IR???
Attilio han girato una fiction in casa tuaaa???
alcarbo
vvtyise@tin.it
buon giorno a tutti!
Solo ora riesco ad entrare nel forum, state avendo anche voi problemi?
SkZ
salve a tutti!
ieri sera ero a pezzi e a nanna presto
La Martina la conoscevamo. Mi pare la prima che hai postato (quella che era a luglio 2007 appena maturata, giusto?)
Complimenti ad Attilio per la posa accattivante.
nippokid (was here)
Hello!
In ritardo, ché mi era sfuggito, ma: Auguri Cary! ...addirittura 17 anni!! dry.gif dry.gif
danardi
Notte
Attilio PB
Saluto volante e ninna, troppo champagne stasera...
Attilio
vvtyise@tin.it
buona domenica!
Attilio PB
Eccomi qui, pensavo di non riuscire a passare, invece resisto strenuamente...
Per Martina, non ricordo a dir la verità, dici che sono gia' quasi due anni che la fotografo? Puo' darsi eh..., mi sembra tanto, ma puo' darsi...
Invece per raffer che si lamenta pubblicamente delle foto che posto, stasera ho preparato uno scatto tutto per lui:
Se vuoi ti spiego tutto il set per filo e per segno, il forum serve a questo no? wink.gif
Vabbe', girello alla ricerca di uno spacciatore alternativo di hard disk FW800
Attilio
nippokid (was here)
Attilio PB
Orpo, non l'avevi letto? E' notevolissimo, una delle migliori cose lette negli ultimi mesi...
Aspettati un MP...
nippokid (was here)
C@zz, ma non riesco a restare connesso...mi sputa fuori ogni due minuti!!
...ora provo a riavviare, cancellare cache, cookies, tutto...non se poffà
Ciao Attilioooo....
Attilio PB
Capperi ( rolleyes.gif ), non credevo fosse cosi' difficile trovare spacciatori di hard disk in rete con un minimo di disponibilità e prezzi competitivi..., cerchero' meglio ma finisce che torno dal mio solito negoziante...
nippokid (was here)
Rieccomi, forse ce la faccio...mi sarò connesso 20 volte in 10 minuti... wacko.gif
Funzionerà? hmmm.gif ...invia!!
EUREKA!!
danardi
notte a tutti
nippokid (was here)
'notte danardi.
...però bastavano 100Kb dry.gif ...così mi annichilisci la banda cerotto.gif
In due mi avete seccato 1/50esimo di monteMB giornaliero!! GRRRRRR...
Ora devo rispamiare Byte...sennò ti cercavo l'HD nei miei super negozi!! dry.gif
Attilio PB
Vado a ninna anche io, l'hard disk lo cerco domani, ho ancora 3 Gb e mezzo di autonomia prima di arrivare agli ultimi dieci che lascio liberi...
Notte a tutti
Attilio
