NikonClub.it Community > PRODOTTI NIKON > NIKON PRODUCTS FAN CLUB
Pagine: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618
raffer
QUOTE(yado3 @ Jan 31 2010, 10:25 PM) *
Nessun problema ad aggiungerte la reione, ma mi dovete spiegare comew si fa??!!
Cliccando sul tuo nickname alla sinistra di un qualunque tuo messaggio appare un menu a discesa. In esso clicca sulla voce "Visualizza la mia pagina", sulla sinistra della quale, sotto "Regione di appartenenza", c'è l'opzione "Regioni:". Basta cliccare sulla freccia alla sua destra per visualizzare l'elenco delle regioni italiane e selezionare quella di appartenenza.
Raffaele
NKNRS
QUOTE(samantha1 @ Jan 31 2010, 05:59 PM) *
La foto è stata scattata a 1600 iso
105mm
f 5.6
no flash
1/100 (ma richiedeva di più infatti non sono congelate come dovrebbero le foto questa ed altre)
Notate il rumore scattate con la d3000 ora vorrei sapere con la d90, se avessi scattato a 1/160 (non meno di 1/125) a 3200iso con lo stesso obbiettivo e stessa focale senza flash quindi potendo congelare il movimento anche in altre scene che ho immortalato, il livello del rumore sarebbe decisamente meno?
Ciao,ho visto la foto e vedo il solito rumore che non eliminerai mai con la D3000; con D90 tu avresti potuto scattare a 1/160" con ISO 2000 e non a ISO 3200 senza rumore come da foto che ho postato ieri. Quindi il mio consiglio è : cambia corpo (D90 o superiore) e al limite per il momento tieniti il tuo obiettivo che non sarà luminosissimo ma non è certamente la causa principale del rumore.
Saluti, Roby.
QUOTE(umberto81 @ Jan 31 2010, 09:28 PM) *
Altre due foto dalla spiaggia. Oggi la luce era decisamente migliore. Ho anche raddrizzato la fotocamera per un orizzonte più orizzontale di quanto non lo era ieri.
Molto bene direi, due ottime foto!
Ciao, Roby.
samantha1
QUOTE(NKNRS @ Jan 31 2010, 11:06 PM) *
Saluti, Roby.
Ciao, Roby.
si infatti appena riesco a vendere la d3000 prendo la d90 ma nel frattempo mi informo perchè, dato che il mio porblema è nella fotografia sportiva meglio informarsi prima, scusa quale foto hai postato ieri di sport? me la sono persa??? non arrivano sempre gli avvisi via email delle nuove risposte.
Alcune di quelle foto ora le devo assolutamente sistemare il più possibile perchè ero li perchè me lo hanno chiesto, ho cercato di fare del mio meglio nonostante non adeguatamente attrezzata..
la d3000 va molto bene se non si cerca di spingere gi iso troppo alti in situazioni come quella, è una bella macchina ma non adatta alla maggior parte di foto che mi ritroverò a fare.
Per l'ottica ci ho pensato più avanti la prenderò, una cosa alla volta altrimenti mi impicco per l'astrico!!!!
Ahh una cosa, sò che la d90 ha il controllo auto della distorsione, come và?
Mentre il braketing fatto in quel modo è un peccato!
QUOTE(primoran @ Jan 31 2010, 10:04 PM) *
Ciao Samantha, premesso che il VR serve ad annullare il movimento del fotografo e non del soggetto, e questo lo sai, per "gelare" il movimento servono tempi brevi e sopratutto obiettivi luminosi. A parte questa discussione che seguo sempre perché è una delle migliori di tutto il forum, ho avuto in mano la D90 di amici e soci del mio Circolo Fotografico. L'ho provata e subito dopo ho venduto la mia D80. Mi permetto di suggerirti un 80-200 f:2,8 D usato che trovi a prezzi ragionevoli. E' una grande ottica che uso da dieci anni (presa usata). Buona luce.
Primo.
P.S. Scusate l'OT ma questa discussione andrebbe rinominata così: D Novantisti Anonimi". Possibile che abbiate tanta fobia ad aggiungere la Regione fra i vostri dati personali?
al vr proprio non ci pensavo, ho scattato a un karatechi che almeno come tempo avrei dovuto usare 1/250, di quei salti....infatti le foto sono venute mosse mannaggia, daltraparte se andavo oltre a 1/100 venivano proprio buie le foto o cmq troppo scure!
raffer
QUOTE(samantha1 @ Jan 31 2010, 11:28 PM) *
Per verificare ancora una volta la resa della D90 agli alti ISO con tempi brevi guardati queste foto.
Le eventuali distorsioni a barilotto o cuscino è meglio correggerle con un programma di fotoritocco o con software specializzati come PTLens.
Raffaele
samantha1
QUOTE(raffer @ Jan 31 2010, 11:32 PM) *
Raffaele
caspita il rumore si nota na non è brutto come nelle mie e poi da dire che ha scattato a 1/320 quindi a 1/160 si noterebbe anche meno ad ogni modo, se è leggero poi con noiseware si leva, bè decisamnete meglio direi, poi abbinandoci una lente f.2.8 andrebbe ancora meglio pur perdendo la profondità di campo.
spero di riuscire a prenderla quanto prima mi serve proprio e non solo x una questione di sfizio!
grazie raffaele
buona notte a tutti andrò a nanna sognandomela ahahahah!!!!!!
ciao a domani e grazie a tutti siete fantastici e bravissimi, viste le foto!!!!
Spero di imparare a fare foto belle quanto le vostre con stè benedette digitali prima o poi anzi prima che poi ..
notte
raffer
QUOTE(samantha1 @ Jan 31 2010, 11:46 PM) *
notte
Buonanotte!
Raffaele
ste.pi
@ bin: che dici, così va meglio? rolleyes.gif
NKNRS
No, non credo tu te la sia persa, mi hai pure risposto che era bella e ripresa dall' alto! rolleyes.gif
Mio messaggio nr° 8859 pagina 355.
Buonanotte, Roby.
Bin
ste, mi piace più il trattamento dell'altra (oltre al taglio). Ma la testa meglio!
Sto notando che forse è un po' mossa? La zona di fuoco non è propriamente nitida... O ci vedo male io?
Distorsion a barilotto... Io manco mi ricordavo che aveva sta funzione! LOL! biggrin.gif
(Oh ragazzi però co' ste Regioni la fate un po 'lunga eh! Io per cercare da dove si cambiava c'ho messo trent'anni. E l'ho fatto solo per la vostra insistenza, avevo ormai desistito dalla ricerca quando poi l'ho trovato). Se uno non vuole o non ha voglia di metterla, non è mica obbligato! rolleyes.gif
ste.pi
QUOTE(Bin @ Feb 1 2010, 12:22 AM) *
cerotto.gif ... Ci vedi benissimo! Ieri avevo messo più maschera di contrasto e si notava meno, invece stasera mi sono reso conto anche io!
Vai a spiegarlo tu a mio figlio che deve stare più fermo la prossima volta per lasciarmi il tempo di settare tutto correttamente e di trovare (magari!) anche un punto di appoggio! Ne ho scattate 5 mentre stava al pianoforte, ce ne fosse una nitida al 100%
Bin
eheheheheheh!! le mie prime foto con la D90 l'ho fatte a un bimbo di circa 7 giorni... non dirlo a me quanto sia stato difficile convincerlo a star fermo, cercando di fargli capire che ancora non conoscevo la macchina e non capivo come settare a-s, af-c, af-a, punto singolo, etc...
(santa maschera di contrasto! non riesco più a farne a meno io!)
NKNRS
QUOTE(ste.pi @ Feb 1 2010, 12:33 AM) *
Due piccioni con una xxx! (forse) Prova a settare il tutto prima, blocchi la maf dove vuoi tu e imposti bracketing di esposizione (o D- lighting attivo) e scatto a raffica. Dovrebbe essere tutto piu veloce per il bimbo, in quanto deve solo attendere il tempo dell' inquadratura e della messa a fuoco. Che ne pensi? Non sarà una tecnica da ritratto, ma perchè non provare?
Ciao, Roby.
Ale-r
QUOTE(gioton @ Jan 31 2010, 01:56 PM) *
Col tuo obiettivo, basta mettere su M l'obiettivo (pag. 59).
Comunque, se l'autofocus è in crisi si può provare a passare a Punto AF Singolo (pag. 173), prima di passare al manuale.
Ciao e benvenuto
Giorgio
QUOTE(Diego M. @ Jan 31 2010, 01:57 PM) *
Basta mettere direttamente M sulla macchina.....
Diego
Adesso si capisco ancora meno......
QUOTE(ste.pi @ Jan 31 2010, 09:42 PM) *
Molto OT...
Ma poi ce la fai assaggiare, 'sta D90 cucinata?
Fine OT
luchino84
Buongiorno a tutti quanti...
...e scusate la mia assenza dal forum per il fine settimana! ;-)
Ho notato che abbiamo molti nuovi arrivati....quindi benvunuti a tutti quanti voi...!!!
E adesso per iniziare bene la settimana....un paio di foto....alle vostre critiche... messicano.gif
...un bel'esemplare di aquila....
Immagine ridimensionata: clicca sull'immagine per vederla con le dimensioni originali. Ingrandimento full detail : 2.5 MB
...e un tramondo nelle vicinanze di Cecina...
IPB Immagine Ingrandimento full detail : 6 MB
Ciao a tutti!!!
FabioAlagna
D90 + 18-105 - spiaggia di Mondello - PA
PP: solo piccolo aumento contrasto
IPB Immagine Ingrandimento full detail : 1.1 MB
bye
Fabio
barbarian
QUOTE(Ale-r @ Feb 1 2010, 09:41 AM) *
Sui manuali c'è scritto che se l'obiettivo ha il selettore, è preferibile scegliere M sull'obiettivo invece che sulla macchina, ma non ricordo se c'era spiegato anche il motivo.
Non è necessario che lo metta ad M su entrambi.
pch
Dopo qualche settimana di inattività fotografica, inizio a postarvi qualche scatto fatto.....in casa mentre la figlioletta riposava e mi lasciava quietare!
Opinioni sempre molto gradite.
IPB Immagine Ingrandimento full detail : 804 KB
IPB Immagine Ingrandimento full detail : 667.4 KB
IPB Immagine Ingrandimento full detail : 784.4 KB
samantha1
QUOTE(NKNRS @ Feb 1 2010, 12:18 AM) *
Buonanotte, Roby.
si si ok ora vista, scusa ma qui tra nick, foto ecc si fa confusione un pò..
gioton
Io ti ho detto quello che è scritto nel manuale che puoi leggerti da solo. Ripeto: con obiettivi AF-S (come il tuo), basta mettere su M il commutatore dell'obiettivo, con obiettivi senza motore di messa a fuoco (tipo D o precedenti, che non hanno il commutatore) si mette su M il commutatore della macchina, comunque metti su M entrambi così sei tranquillo.
Giorgio
QUOTE(luchino84 @ Feb 1 2010, 10:32 AM) *
Ciao a tutti!!!
QUOTE(Fabioski @ Feb 1 2010, 10:48 AM) *
bye
Fabio
Dalle polveri sottili di Milano sempre e solo invidia, anche se oggi c'è il sole.
Giorgio
FabioAlagna
QUOTE(pch @ Feb 1 2010, 01:33 PM) *
cut..
Fabio
samantha1
ragazzi il controllo della distorsione sulla d90 è efficace?
Belle tutte le ultime foto postate da vari utenti, per quelle del piano preferisco anche io la terza
ciao :-)
ze
bye
Fabio
Bella! Molto ben congelato anche il movimento e la terra sollevata dagli zoccoli. Che luce da quelle parti!
Sempe con un po' di invidia....
Zeno
luchino84
QUOTE(samantha1 @ Feb 1 2010, 02:17 PM) *
ciao :-)
Quoto in pieno Samanta....anche a me piace molto la terza....! ;-) Bravo!
ze
Ho un piccolo aiuto da chiedervi. La mia attrezzatura informatica ahimè mi sta lasciando... dovendo spendere un po' di soldini per un pc che finalmente impieghi meno di 5 minuti a aprire un nef con Capture... vorrei un parere. Ho già letto le caratteristiche dei pc di alcuni di voi qualche decina di pagine addietro, ma non mi pare di ricordare qualcuno che usi MAC.
Per caso tra voi c'è qualcuno? Come si comporta con i programmi Nikon e con la gestione dei file belli sostanziosi della nostra D90?
Grazie se mi date esperienze dirette o anche per sentito dire.
Zeno
samantha1
QUOTE(ze @ Feb 1 2010, 02:30 PM) *
Zeno
ma non fai prima a aumentare la memoria??
Il mio portatile non andava ma da quando ho cambiato la memoria aumentandola ora va che è una meraviglia!!!
pch
QUOTE(luchino84 @ Feb 1 2010, 02:23 PM) *
Grazie! mi sorge il dubbio che la terza vi piaccia di più solo per la cornice hmmm.gif : la mia preferita era proprio la prima! il mondo è bello perchè vario.
Ne aggiugno un'altra scattata usando i tubi di prolunga. Li avevo dalla vecchia Nikon ed ho pensato di rispolverarli. La MaF è davvero un problema, però con soggetti statici e cavalletto.....domanda: ma anche con un obiettivo macro la MaF è così difficile? Non ne ho esperienza.
di questa foto mi piace l'atomsfera. ah dimenticavo....la scritta sul foglio è lunga circa 2,5 cm!
Immagine ridimensionata: clicca sull'immagine per vederla con le dimensioni originali. Ingrandimento full detail : 1 MB
FotoGolfer
Inanzitutto un caldo benvenuto ai neopossessori!
Belle immagini Pch del piano e degli spartiti, la seconda per me, la migliore.
Fabio che dire dei cavalli, sono una mia passione, peccato per in cavallo di sinistra che non si vede tutto. Buon "congelamento" del momento.
Ze vai tranquillo con apple...........anche se più oneroso..........
Domenica sono andato el pian del Tivano per un esperimento con slittino di mio figlio e dato che l'ultimo esperimento con la neve era risultato troppo grigio ho provato altre soluzioni di esposizione.
IPB Immagine Ingrandimento full detail : 901 KB
IPB Immagine Ingrandimento full detail : 974.6 KB
IPB Immagine Ingrandimento full detail : 678.5 KB
Infine viste le discussione sul pentaprisma spezzato per la MAF, di cui non sento minimamente la mancanza, posto una vecchia foto fatta in Cina con macchina senza af e con il perntaprisma spezzato appunto.
IPB Immagine Ingrandimento full detail : 879.6 KB
FotoGolfer
Mi dimenticavo............Luchino bello il tramonto.........che bella la toscana.
luchino84
QUOTE(FotoGolfer @ Feb 1 2010, 03:14 PM) *
Grazie Enrico,
gentilissimo........la mia madre terra non mi tradisce mai effettivamente!!! EHEHEH messicano.gif
Grazie ancora!
Trall'altro davvero molto be realizzate anche le tue sulla neve....soprattutto la seconda mi pare davvero ottima!!!
Obbiettivo?
barbarian
QUOTE(pch @ Feb 1 2010, 02:57 PM) *
Della prima serie preferisco la terza perché mi sembra più pacata e rilassante.
La prima invece la trovo un po' troppo forte.
Questa'ultima pure mi piace perché mi da un senso di relax.
luchino84
QUOTE(barbarian @ Feb 1 2010, 03:23 PM) *
Sono in piena linea con il tuo pensiero!!!
FotoGolfer
CODE
Obbiettivo?
Nikon 24-70 2.8
luchino84
QUOTE(FotoGolfer @ Feb 1 2010, 03:22 PM) *
CODE
Obbiettivo?
Nikon 24-70 2.8
eheh....giuro che lo immaginavo...!!!
Non sai quanto ti invidio....prima o poi sarà mio.....più poi che prima purtroppo per il costo che ha!!! messicano.gif
Luigi_FZA
CODE
Obbiettivo?
Nikon 24-70 2.8
Vi seguo da un po di tempo, pur essendomi presentato nell'area "Ufficiale", non ho mai provato a scrivere qui ma ora mi vedo "costretto" perche' mi sembra di capire che FotoGolfer (o almeno te) hai montato il 24-70 sulla 90.
Mo siccome sto valutando (e risparmiando) di prendere un obiettivo simile (rigorosamente usato) chiedo trovi l'accoppiata: 90 & 24-70 in termini di "maneggevolezza".
Grazie.
luchino84
QUOTE(arciere_ISR @ Feb 1 2010, 03:44 PM) *
Grazie.
purtroppo questa è una risposta che ti può dare solo FotoGolfer o chi, come lui possiede il 24-70.
Io faccio ancora parte di quelli che come te....riempiono salvadanai ovnunque con la speranza di arrivarci presto! messicano.gif
raffer
Nikon 24-70 2.8
Dai dati Exif la seconda sulla neve risulta essere stata fatta a 300 mm. ohmy.gif
Raffaele
luchino84
QUOTE(raffer @ Feb 1 2010, 04:00 PM) *
Raffaele
Ad ogni modo il mio desiderio sul 24-70 non cala!!! AHAHAH
jacleon
la prima è 70mm (diaframma 2.8), e potrebbe essere...
karl mark
...... ma non mi pare di ricordare qualcuno che usi MAC.
Ciao Zeno....se ne hai la possibilità vai di Mac !
Con i seguenti programmi aperti: Photoshop, Capture NX2, (più di un NEF aperto), 5-6 pagine di internet, musica, chat e qualche applicazione di office non ho mai rallentamenti o blocchi.
View NX e Capture non sono schegge....ma nulla di snervante comunque....
Grazie.
Non so che obiettivi hai e con cosa sei abituato. Il 24-70 non è di certo una piuma, io con il battery pack, trovo il tutto equilibrato e non eccessivamente pesante....ma qui si entra su abitudini e preferenze personali....
Certo, la maneggevolezza ce l'ho quando ho montato il 50ino o il 10.5.... smile.gif
FotoGolfer
Ciao Raffaele
può darsi, per provare la difficile esposizione sulla neve, posso aver fatto qualche casino.
Ho scattato circa 400 foto e con vari obbiettivi.
Vedo che sei sempre molto attento!
L'accoppiata d90 24-70 piu' motore e' pesante, ma come si può pretendere altro?
Stasera posterò altri scatti per illustrare la differenza dei vari obbiettivi sulla neve.
pch
QUOTE(FotoGolfer @ Feb 1 2010, 04:08 PM) *
Interessante. Non vedo l'ora!
Luigi_FZA
QUOTE(luchino84 @ Feb 1 2010, 03:49 PM) *
QUOTE(karl mark @ Feb 1 2010, 04:04 PM) *
.... Non so che obiettivi hai e con cosa sei abituato. Il 24-70 non è di certo una piuma, io con il battery pack, trovo il tutto equilibrato e non eccessivamente pesante....ma qui si entra su abitudini e preferenze personali.... Certo, la maneggevolezza ce l'ho quando ho montato il 50ino o il 10.5.... smile.gif
@ luchino84 : Io lo prenderei usato da una persona che conosco, e che sebbene sia "assetata" di soldi non vuole skioda' dalla cifra inizialmente chiesta!!
@ karl mark : Concordo circa il peso del 24-70 : l'ho qui vicino mentre scrivo texano.gif ! io sono abituato al 16-85 ed al 12-24, inizialmente al 18-105.
luca.f
@Stefano
A mio avviso meravigliosa la foto al tuo bimbo sul pianoforte: il momento, la drammaticità della posizione, lo sfocato (come Bin, guardandola bene, lo preferisco com'è: con l'occhio ed il viso non a fuoco), l'atmosfera ottenuta con la conversione (preferisco la prima versione, ma non il taglio).. insomma per me è un gran scatto.
So bene cosa significa 'inseguire l'attimo fuggente' con i bambini, e i consigli di Roby mi sembrano ottimi. Poi però non bisogna esagerare con il 'cannone' altrimenti il bimbo/a si indispettisce e se prende in antipatia la fotocamera sono guai.
@Pietro
Delle foto a pianoforte e spartiti a me piace soprattutto l'ultima: molto bella e particolare così macro.
Ottima resa dei tubi di prolunga che, per la verità, sento citare da tempo ma non ho mai visto nè utilizzato.
@Enrico
Ottime davvero le tue foto sulla neve!
Esposte correttamente al limite sul bianco e ottimi anche i colori.
Saluto tutti con due scatti.
Niente di chè ma sono quanto di meglio sono riuscito a fare nel weekend rolleyes.gif .
D90 e Nikkor 17-35 2.8.
-16 C°
Solo -6 C°
luca
Diego M.
Ciao a tutti!!!
Bello il tramonto di Cecina che se non ricordo male è vicino a Bibbona!!!!!!Giusto hmmm.gif
Ciao Ciao Diego
luchino84
QUOTE(Diego M. @ Feb 1 2010, 05:16 PM) *
Ciao Ciao Diego
Ciao Diego....
....grazie tante per i complimenti....stai diventando il mio "estimatore" preferito! AHAHAH grazie.gif
Per quanto riguarda il tramonto a Cecina....si Cecina non è lontanissimo da Bibbona....!
In questo caso....la foto è stata scattata tra Cecina e Vada....località La Mazzanta! ;-)
Diego M.
QUOTE(luca.f @ Feb 1 2010, 04:49 PM) *
-16 C°
luca
Diego
piede89
Salve a tutti,oggi è il mio primo giorno sul forum. Ho da poco comprato una bellissima nikon d90 kito 18-105.
Non sono esperto di fotografia,me la cavicchio ma soprattutto mi piace troppo fotografare! volevo chiedere a qualcuno,magari in possesso della mia stessa macchina,se c'è qualche consiglio o qualcosa in particolare da sapere per fare delle belle foto con questa d90. Spero presto di caricare qualche foto così da poter leggere qualche commento costruttivo. grazie a tutti
A presto [size="2"][/size]
Fragius
Aggiungo altre 3 foto scattate durante la mia permanenza nei Paesi Baschi:
La prima è una scultura di arte moderna di Jeff Koons, installata presso il museo del Guggenheim, raffigurante dei tulipani colorati.
IPB Immagine Ingrandimento full detail : 804.4 KB
Nelle altre 2 foto: architettura contemporanea a Bilbao biggrin.gif
IPB Immagine Ingrandimento full detail : 2 MB
IPB Immagine Ingrandimento full detail : 1.8 MB
Diego M.
QUOTE(piede89 @ Feb 1 2010, 06:10 PM) *
Devi leggere il manuale, e leggi il forum qui troverai tanti consigli utili...... messicano.gif
Le foto meglio se le scatti in Raw e magari alzi un pò la nitidezza.....
Dovresti mettere anche la regione di appartenenza......
Diego
raffer
A presto
Raffaele
QUOTE(Fragius @ Feb 1 2010, 06:12 PM) *
Raffaele
