NikonClub.it Community > PRODOTTI NIKON > NIKON PRODUCTS FAN CLUB
Pagine: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618
primo morandini
QUOTE(raffer @ Jan 9 2009, 09:31 PM) *
Dopo aver scritto il messaggio basta cliccare con il tasto sinistro del mouse (Windows?) sul bottone "Aggiungi la Risposta" che si trova sotto l'area nella quale hai scritto il testo.
Per ciò che concerne lo SB-800 devi affrettarti poichè è uscito di produzione e tra un po' potrebbe diventare difficile trovarlo.
Raffaele
Grazie! Bella la frase in fondo al riquadro, di chi è?
Questa è di Bertrand Russell: Gli innocenti non sapevano che la cosa era impossibile, quindi la fecero.
giovannettone
ciao a tutti
oggi ho chiesto se qualcuno ha provato il gps gp1 per la d90, se sì come va?? dove lo posso trovare ed a che prezzo, grazie a tutti gianni
raffer
QUOTE(primo morandini @ Jan 9 2009, 09:42 PM) *
Di questo tipo:
Raffaele
raffer
QUOTE(giovannettone @ Jan 9 2009, 10:10 PM) *
... dove lo posso trovare ed a che prezzo
Per trovarlo basta che fai una ricerca su Google.
Se vuoi ti posso mandare via MP il link.
Raffaele
N1lo
QUOTE(N1lo @ Jan 9 2009, 09:52 AM) *
Salve a tutti...
sono un nuovo possessore della Nikon D90 dal 2 gennaio...
(Ho acquistato il Nikon D90 kit con il 18-105 che comprendeva anche la memory card LEXAR 4GB 60X)
Ieri sera con mio grande spavento dopo un paio di scatti la macchina ha smesso di funzionare e sul display compariva un messaggio di errore CHA che impediva il funzionamento di tutta la macchina compresa levetta ON/OFF lasciando la macchina accesa...
Ho rimosso la batteria e la macchina è per magia tornata a funzionare normalmente senza aver cancellato nessuna foto interna.
Secondo voi devo portarla in assistenza o è una eventualità "normale" essendo cmq un apparecchio completamente digitale??
Grazie a tutti!
Stamattina 10/01 il problema si è ripresentato ma è durato 30 secondi in quanto ormai so che togliendo la batteria tutto va a posto...
Secondo voi la devo far controllare??
Cavolo è solo una settimana che la ho :(
vvtyise@tin.it
pur se non è una cosa grave, rimane una bella scocciatura. Prova a fare una telefonata all'assistenza, può essere utile.
N1lo
QUOTE(vvtyise@tin.it @ Jan 10 2009, 11:49 AM) *
Si asolutamente non è una cosa grave, ma è appunto una rottura soprattutto mentre si è nel mezzo della scena:D!!!
Scoccia che sia già dopo una settimana di utilizzo molto tranquillo...
Proverò a seguire il tuo consiglio, grazie mille!!!
gioton
QUOTE(jpetrucci @ Jan 9 2009, 09:37 PM) *
attenzione a suggerire acquisti all'estero..
a me hanno cancellato un post perchè secondo i moderatori "istigavo" all'acquisto in inghilterra, la politica Nital non può certo favorire tali acquisti.
ciao ciao
Hai ragione, chiedo scusa, nel caso cancellassero il mio messaggio ripeto qui l'altra parte del discorso che ho fatto e che ritengo possa interessare molti, che sono tentati dagli acquisti via Internet fuori CE:
"Attenzione! Al di là della fiducia nel fornitore, che bisogna avere, prima di fare un ordine importante, c'è un altro aspetto da tenere in considerazione: i dazi doganali, vi racconto due mie esperienze:
1. Ordinato attraverso Ebay da Hong Kong (questo dà già una certa sicurezza, rispetto a un fornitore diretto, ma conviene guardare anche qui) un moltiplicatore di focale, il fornitore me l'ha spedito dichiarandolo un omaggio di valore irrisorio e mi è arrivato regolarmente senza costi aggiuntivi.
2. Ordinato dei cd musicali, trovato che Amazon USA era circa il 20% più economica di Amazon France li ho ordinati in America. Li ho ricevuti regolarmente... con un contrassegno del 20% da parte della Dogana italiana a titolo di dazio doganale."
gioton
QUOTE(N1lo @ Jan 10 2009, 11:42 AM) *
Consiglio anch'io una telefonata all'assistenza, ma hai provato a pulire i contatti come ti ho suggerito? per quelli interni al vano batteria puoi usare un cotton fioc.
Hop-Frog
Mi sembra un'anomalia fastidiosa, non di poco conto... secondo me dovresti farla controllare :-(
N1lo
QUOTE(gioton @ Jan 10 2009, 02:42 PM) *
Si certo.. Anche se cmq mi sembra strano si siano sporcati visto che al momento è uscita da casa praticamente 3 ore ed è cmq tenuta sempre iperimballata per evitargli polvere e quant'altro...
A voi non è mai successo???
Se dopo una settimana fa gia sti numeri... e mi tocca mandarla in assistenza dove la aprono e la lavorano all'interno...
Bah... Speriamo non sia nulla...
Lunedi chiamo in assistenza, nei weekend sono chiusi...
raffer
QUOTE(N1lo @ Jan 10 2009, 06:04 PM) *
Se riesci a sapere qualcosa mi fai il piacere di comunicarcelo? rolleyes.gif
Raffaele
vvtyise@tin.it
è una cosa che interessa tutti noi che abbiamo la D90.
N1lo
QUOTE(vvtyise@tin.it @ Jan 10 2009, 06:23 PM) *
Certo nel frattempo ho creato una discussione legata al problema (Nikon D90: Errore CHA), in modo tale da non scocciare troppo i fortunati che possiedono la D90 priva di problemi...
Cmq sono tentato oltre che a chiamare in assistenza ad andare nel negozio dove l'ho comprata...
Su una spesa di 1200 euro mi aspetterei che la Nikon avesse estremo riguardo a creare prodotti il piu possibile privi di errori, soprattutto grossolani come questi e quindi spero che sia un errore "passeggero" anche perchè non l'ho fatta ancora entrare in azione seriamente, l'ho piu che altro provata tra le mura domestiche e un paio d'ore d'aria una volta sola (in strada e non in una tempesta di sabbia...)
Non potendo spegnere la fotocamera quando mi compare l'errore CHA (per ora 2 volte in pochi giorni) in quanto la levetta ON/OFF non risponde al comando, sono costretto a rimuovere e rimettere la batteria e questo non vorrei danneggiasse cose piu serie!!!
Hop-Frog
QUOTE(N1lo @ Jan 10 2009, 07:50 PM) *
Assolutamente sì!
gabri.56
salve a tutti!
volevo chiedere ai possessori della D90 se potrebbero postare un pò di foto ad alti Iso 400-800-1600 ovviamente se possibile?
perchè sto valutando l'acquisto della D90 ma sono molto perplesso per le prestazioni ad alti ISO
io ho una D40 e posso andare tranquillamente a ISO 800 e 1600
volevo capire se posso fare altrettanto con la D90
raffer
QUOTE(gabri.56 @ Jan 10 2009, 09:10 PM) *
salve a tutti!
Guardati le foto postate in questa stessa discussione a pag. 42 Messaggio #1012 e giudica un po' tu! dry.gif
Per adesso te ne metto una mia a 1800 ISO a mano libera.
Ingrandimento full detail : 369.2 KB
Raffaele
Hop-Frog
salve a tutti!
Beh... sarebbe assurdo se non potessi fare altrettanto, visto che la D90 è ben più recente e appartiene ad una fascia di prezzo superiore. Non capisco da dove derivino le tue perplessità sulla resa della D90 ad alti iso, visto che - tra l'altro - tutti i test ne evidenziano l'ottimo comportamento... proprio la resa ad alti valori ISO è forse la sua caratteristica più apprezzata.
Poi: con la D50 a 1600 iso le foto erano spesso troppo rumorose anche solo per una pubblicazione su web... e dubito che la D40 faccia molto meglio... quindi penso che dovresti rimanere estasiato dai risultati della D90, con questo metro di giudizio.
Saluti!
primoran
QUOTE(raffer @ Jan 9 2009, 10:23 PM) *
Di questo tipo:
Raffaele
Grazie Raffaele, vorrei abusare ancora della tua gentilezza/pazienza per alcuni quesiti:
sulla D90 leggo che potrò usare il portabatterie MB - D80 e questo è un vantaggio; potrò
usare anche i comandi a distanza ML-L3 e MC-DC1???
Un geometra in pensione (Udine) chiede aiuto ad un architetto in pensione (?) se ho letto
bene una tua risposta sul forum per altri argomenti.
Grazie P: Morandini
raffer
QUOTE(primoran @ Jan 10 2009, 10:39 PM) *
Grazie P: Morandini
Un architetto in pensione (Napoli) ti conferma l'uso sulla D90 dello MB-D80, del telecomando ML-L3 e di quello MC-DC2 (e non MC-DC1) preferibile al primo, anche se via cavo.
Raffaele
alvise.susmel
Pazzesco, alle 5:30 di notte ( e c'era buio pesto!!) ho fatto una foto con tempo di esposizione 30 secondi e iso 200, sembra che l' abbia fatta di giorno!!
vvtyise@tin.it
notevole!
franco9
QUOTE(alvises @ Jan 11 2009, 07:27 AM) *
Questa prerogativa del digitale, e non della D90, non mi piace poi tanto!
raffer
QUOTE(franco9 @ Jan 11 2009, 12:34 PM) *
Comunque, volendo, si può fare abbastanza facilmente anche con il digitale.
Raffaele
Hop-Frog
Secondo me non è tanto questione di digitale quanto di d-lighting... ho fatto la stessa prova (scatto notturno con 30" di esposizione, 200 iso) e i risultati sono stati molto diversi con e senza d-lighting attivo.
Caterpillar86
QUOTE(thebigciro @ Nov 8 2008, 09:33 PM) *
Grazie per l'aiuto riguardo il pixel morto. Andrò da un centro assistenza. Sapete per caso se a Roma ne esiste uno affidabile a cui portare la macchina appena comprata e quindi in garanzia?. Grazie ancora
C'è Dear Camera ( www.dearcamera.it ) che ha tutta l'attrezzatura di laboratorio fornita dalla Nikon per fare le riparazioni. Son altamente qualificati
primoran
QUOTE(raffer @ Jan 10 2009, 11:01 PM) *
Raffaele
Caro Raffaele, grazie per la dritta. Siccome ho trovato un compratore per la mia D80, ed è interessato
solo al corpo ed al 18/70, mi terrò gli accessori di che trattasi senza bisogno di cercare compratori o
di regalarli. Mi sarei orientato su D90 + 16/85+SB800. Questo perché non faccio un grande uso del
flash. Con la F100 avevo un SB28 che ho usato pochissimo.
Mi tenta però anche l'offerta "titanica" del Kit D90+18/105+SB900 a 1.400 caffè che mi farebbe risparmiare 200 caffè. Così se ne avantaggerebbe il portafoglio ed i nervi.
Ciao e grazie per la pazienza.
P. Morandini (da ora in poi: primoran)
raffer
QUOTE(primoran @ Jan 11 2009, 08:29 PM) *
Tra le due ipotesi io preferirei la prima sia perchè il 16-85 è sicuramente superiore al 18-105 sia perchè lo SB-800 è più che sufficiente. Oltre tutto tu stesso dichiari di fare poco uso del flash.
Raffaele
primoran
QUOTE(raffer @ Jan 11 2009, 08:44 PM) *
Raffaele
I nervi per l'indecisione. Mi sembra di non aver mai valutato tutto.
A punto ho deciso per la soluzione con il 16/85!!
http://www.nikonclub.it/forum/style_emotic...efault/guru.gif
gioton
QUOTE(primoran @ Jan 11 2009, 09:02 PM) *
Io ho D90+16-85 e sono più che mai convinto che QUESTA E' LA SCELTA, piuttosto, perchè il flash, per usarlo poco? io uso quello della macchina e mi basta.
gioton
Ho dimenticato di chiederti se sai che D90+16-85 è un Kit, venduto a un prezzo inferiore di quello corpo+obiettivo. Guarda qui.
primoran
QUOTE(gioton @ Jan 12 2009, 04:33 PM) *
Grazie Raffaele, vedi che ragionando in due, sia pure a distanza, funziona meglio. In effetti il flash che
avevo (SB28) lo usavo qualche volta per la macro ma il più delle volte preferivo farla a luce ambiente.
Forse perché la F100 non aveva il suo flash incorporato.
Per quanto riguarda il Kit, l'ho trovato sul Titano, dove mi servo abitualmente con grande soddisfazione sia per il servizio che per il risparmio. Lì il kit costa 1.265 caffè, con garanzia Nital, più 15 caffè per le spese di spedizione via corriere, a loro rischio, perché non si versa niente prima di aver ricevuto e controllato la merce.
Approfitto ancora della tua gentilezza, come si fa a portare le faccine sul messaggio?
primoran
raffer
QUOTE(primoran @ Jan 12 2009, 09:43 PM) *
Basta posizionare il cursore nel testo e poi cliccare sul bottone "Emoticons" (vedi immagine allegata).
Se vuoi vedere tutte quelle disponibili clicca su "Mostra tutti". Facile ... no? rolleyes.gif
Raffaele
arpex
Ciao ragazzi volevo 2 consigli per 2 obiettivi... Quale consigliereste per fotografie macro e quale per avere un ampio grandangolo? grazie. ovviamente che non serva un mutuo per comprarli..
raffer
QUOTE(arpex @ Jan 14 2009, 09:39 AM) *
Per la macro c'è lo AF-S 105/2,8 VR e come grandangolo estremo lo AF 10,5/2,8.
Raffaele
primoran
QUOTE(raffer @ Jan 12 2009, 10:31 PM) *
Raffaele
Grazie Raffer, mi sarebbe gradito il tua parere sui miei obiettivi, già segnalati.
grazie.gif primoran
raffer
QUOTE(primoran @ Jan 14 2009, 09:33 PM) *
grazie.gif primoran
Scusa, ma non sono riuscito a ritrovare quali sono i tuoi obiettivi. dry.gif
Potresti elencarmeli di nuovo? Grazie!
Raffaele
arpex
Buongiorno a tutti, ho acquistato la D90 il 20 dicembre. Dopo una settimana il primo hot pixel di colore celeste visibile solo dagli 800 ISO in su. Ieri sera il 2° di colore rosso...
Il negoziante la settimana scorsa mi aveva detto che me la avrebbe cambiata, molto cortese, ma per uno solo avevo deciso di lasciar perdere. Ora sono diventati 2 in meno di un mese, comincio a temere il trend poco incoraggiante, non vorrei aumentassero velocemente! a voi è mai successo? come mai si vedono solo dopo gli 800 ISO, dipende dalla sensibilità che diamo al sensore? alla fine del discorso voi che fareste? non vorrei che anche cambiando trovassi di peggio, ma sarebbe troppa sfiga..
raffer
QUOTE(arpex @ Jan 15 2009, 09:34 AM) *
Sei sicuro che sono hot pixel? Perchè non posti qualche immagine esemplificativa?
Raffaele
P.S. Perchè, oltre a questo messaggio, hai aperto anche una discussione uguale? dry.gif
arpex
ciao raffer, si sono sicuro, ora non l'ho dietro la foto, la posterò magari domani ma comunque sono sicuro, uno celeste e uno rosso.. ho aperto un'altra discussione per dare piu' visibilità alla domanda e ricevere + consigli? perchè ho sbagliato?
raffer
QUOTE(arpex @ Jan 15 2009, 03:11 PM) *
Il regolamento del Forum vieta di inviare lo stesso post in più discussioni. dry.gif
Raffaele
arpex
ops..scusate non lo sapevo, sono un novizio..
2s_nikon
Ciao, purtroppo ne ho uno anch'io. Nella D40 ne avevo 5. Diciamo che fanno compagnia.....
2s_nikon
Sopra alla testa perpendicolare al microfono c'è il pixel verde, ogni commento pixel a parte è gradito.
primoran
QUOTE(raffer @ Jan 14 2009, 10:16 PM) *
Raffaele
Caro Raffer, i miei obiettivi sono: 20 mm 2,8 -- 50 mm 1,4 -- 28/105 mm 3,5/4,5 -- 80/200 mm 2,8 a
due ghiere e 300 mm 4. Tutti Nikkor ed inoltre Sigma: macro 105mm 2,8 e Teleconverter 1,4X.
Grazie per l'attenzione e scusa il disturbo.
primoran.
raffer
grazie.gif primoran
Purtroppo prima di approdare al digitale non ho mai avuto una reflex Nikon per cui circa i tuoi vecchi obiettivi potrei darti solo informazioni di seconda mano.
Ti conviene chiedere direttamente nella sezione "Obiettivi Nikkor" del Forum dove troverai utenti molto più esperti di me.
Raffaele
gioton
QUOTE(primoran @ Jan 15 2009, 08:37 PM) *
primoran.
Sono andato a vedere nella tua pagina i tuoi messaggi e ho visto che fotografi a livello professionale. Se così è e pensi di usare la D90 anche per scopi professionali ti consiglio senz'altro il 16-85 invece del 18-105. Per quanto riguarda i tuoi vecchi obiettivi dovresti poterli utilizzare tutti, tenendo presente che il 50mm nel formato DX si comporta come un 75 nel 24x36 ecc.
UBYRO
Salve a tutti , io sono un giovane Nikonista di 53 anni che ha appena acquistato il kit D90 18-105 . Ho seguito le varie discussioni e da vero neofita Vi sarei grato se qualcuno , senza che debba andare a ducumentarmi su manuali particolari , mi spiegasse la differenza fra tecnologia FX e Dx .Per quel poco che sono riuscito ad imparare , in questo breve tempo , ritengo la D90 un gran bel prodotto.
UBYRO
Clicca per vedere gli allegatiClicca per vedere gli allegati[attachm
ent=121700:Immagine_087.jpg]Clicca per vedere gli allegati qualcuno mi da un giudizio tecnico sulle foto allegate D90 - 18 -105
raffer
QUOTE(UBYRO @ Jan 17 2009, 06:39 PM) *
mi spiegasse la differenza fra tecnologia FX e Dx.
Sintetizzando e semplificando al massimo: il formato FX usa sensori delle dimensioni del vecchio formato 35 mm a pellicola, cioè 24x36; il formato DX adopera invece sensori che sono esattamente la metà degli FX, cioè 18x24. Tale riduzione di dimensione del sensore ha conseguenze sul comportamento degli obiettivi che, inqudrando un'area più piccola, si comportano come ottiche di focale maggiore. Per esemplificare un 16 equivale ad un 24, un 24 ad un 36, un 50 ad un 75 e così via poichè il fattore di allungamento è proprio 1,5.
Raffaele
