NikonClub.it Community > PRODOTTI NIKON > NIKON PRODUCTS FAN CLUB
Pagine: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603
raffer
QUOTE(micweb @ Dec 11 2011, 12:05 PM) *
E forse andarci un po' più leggeri con la MdC
scusa raffer. puoi tradurre?
grazie.
MdC = Maschera di Contrasto.
Un suo uso non corretto porta ad effetti come quelli evidenziati nell'immagine nel profilo degli edifici. dry.gif
Raffaele
kalio1987
QUOTE(simonespe @ Dec 10 2011, 02:53 PM) *
il club si affina....
complimenti per le ultime immagini postate...
contributo paesaggistico.....
sigma 8-16 ,F/11 ,1/160 , iso 100 ,8mm
Bella Simone, molto bella
grazie.
Maschera di Contrasto, una funzione di photoshop che ti permette di aumentare il contrasto dei dettagli esaltando la nitidezza.
Dato che qui è sempre nuvoloso posto qualche foto non proprio recente
DSC_6146-Modifica.jpg di kalio87, su Flickr
DSC_6116.jpg di kalio87, su Flickr
DSC_6082.jpg di kalio87, su Flickr
DSC_6086.jpg di kalio87, su Flickr
Quest'ultima non ricordo se l'avevo messa.
micweb
QUOTE(raffer @ Dec 11 2011, 12:29 PM) *
Raffaele
oraziotp
Ancora Backfocus? si scusatemi...
Ragazzi ho bisogno di un consiglio da voi:
l'argomento è stato trattato e ritrattato, ho letto tutto il possibile specie su questo forum, ma sono nel dubbio e, semplicemente vorrei sapere se, al mio posto voi, spedireste la fotocamera in assistenza
Noto un problema di messa a fuoco (nello specifico BackFocus) nel senso che la fotocamera impostata in AF S con punto centrale, mette a fuoco una zona posteriore rispetto a quella impostata nel mirino, difetto che non si presenta invece se si effettua in medesimo scatto in modalità LiveView.
Di conseguenza confrontando il medesimo scatto (effettuato su cavalletto con comando a distanza e mirror UP); le foto scattate attraverso il mirino e quelle scattate in modalità LiveView presentano marcate differenze nel punto di fuoco ottenuto, a fronte del medesimo punto di fuoco impostato.
E' possibile LIMITARE il difetto ricorrendo alla funzione "Regolazione fine AF" presente sulla fotocamera, impostando per i vari obiettivi in mio possesso valori diversi che sembrano essere in funzione del diaframma di massima apertura dell'obiettivo.
Nello specifico i valori di Regolazione fine AF:
AF-S NIKKOR 70-300mm 1:4.5-5.6G ED VR richiede una impostazione di -5 per limitare il backfocus
AF-S NIKKOR 18-105mm 1:3.5-5.6G ED VR DX richiede una impostazione di -8 per limitare il backfocus
AF NIKKOR 35-70mm 1:2.8 D richiede una impostazione di -13 per limitare il backfocus
AF NIKKOR 80-200mm 1:2.8 ED richiede una impostazione di -15 per limitare il backfocus
Qui di seguito un piccolo esempio...
AF-S senza Regolazione fine AF con lente 18-105 a 105mm f1/5.6
LiveView con lente 18-105 a 105mm f1/5.6
AF-S con Regolazione fine AF -8 con lente 18-105 a 105mm f1/5.6
Gli oggetti nelle foto sono arretrati tra loro di circa 2 cm ognuno e le foto sono scattate da circa 1,7 mt di distanza.
Le foto sono dei ritagli in formato TIFF della zona di fuoco (evidenziata in giallo) dove più è evidente il difetto da me riscontrato.
P.s. in luce artificiale a volte i problemi aumentano....
Sapendo che dovrei rimanere senza fotocamera per circa un mese voi cosa fareste?
leo1251
QUOTE(oraziotp @ Dec 11 2011, 08:05 PM) *
Francamente, almeno dalle foto postate, io non riesco a vedere problemi così seri, in ogni caso sei tu a dover decidere, se ritieni di non essere sodisfatto sicuramente l'assistenza potrà levarti eventuali dubbi.
La regolazione fine sugli zoom serve a poco o, meglio, a nulla.
oraziotp
Forse questo esempio rende meglio il problema....
il set, un pò casalingo certo...
e i risultati a confronto...
gioton
QUOTE(oraziotp @ Dec 12 2011, 10:17 AM) *
Suppongo che il punto che hai messo a fuoco sia il faccino con la scritta 0-14, se così è credo che non ti resti che da inviare la macchina a LTR, magari dopo le feste, per farla star via meno tempo. Dato che ci sei, controlla anche la pulizia del sensore con una foto di uno sfondo omogeneo, sfocato con diaframma tutto chiuso, questo è il mio sensore oggi , scattato su una parete bianca da circa 1m con fuoco a infinito, ovvio che se, come è evidente, dopo oltre 5000 scatti il mio otturatore sputa ancora goccioline d'olio sul sensore, anche la mia macchina partirà presto per LTR:
Giorgio
leo1251
Non è scientifico come test ma... hai reso bene l'idea!
In assistenza, sicuramente, ma solo D7000 e niente ottiche, a mio parere.
oraziotp
@leo1251 e gioton Vi ringrazio tanto ragazzi per il sostegno.@ gioton Il sensore è sporco ma per fortuna solo di polvere! Credo!
P.s. Bisogna inviare a LTR garanzia e scontrino in originale o vanno bene anche delle copie?
Giacomo.terra
Giacomo.terra
Pomeriggio fotografico al beach tennis, per la primissima volta ho provato a fotografare questo sport...
Foto con sigma 24-70 f2.8 e nikon 70-200 f2.8
Quelle a busto intero e di coppia sono col sigma le altre col nikon
Tutte le foto sono state scattate a 1/400s, f2.8 ISO 3200 (Buio pesto), qualità Fine larghezza M
tigertank
Ciao Giacomo, davvero ottime considerando gli iso a 3200!
Mi è arrivato il sigmone, un piccolo lanciamissili(come il Nikon presumo)! Appena ne avrò occasione posterò eventuali foto degne di questo prestigioso club wink.gif
Giacomo.terra
QUOTE(tigertank @ Dec 12 2011, 04:46 PM) *
reclinato
ciao tiger, quale sigma hai preso? la versione OS o non OS?
ci sto pensando anche io di dar via il 70-300 e prendere il sigma... (il nikon costa troppo e il tamron a quanto dicono è troppo lento)
facci vedere qualche prova se puoi...
prospero
leo1251
QUOTE(oraziotp @ Dec 12 2011, 12:43 PM) *
La garanzia (Nitalcard) in originale, scontrino anche in copia.
Mandi direttamente tu o attraverso rivenditore?
Chiedi conferma a LTR nel primo caso oppure al tuo fotonegoziante nel secondo, allega un cd con alcune prove da te fatte e due righe esaustive a commento.
Accertati che il sensore sia effettivamente sporco di polvere e non di olio (trovi qui nel club e in vari topic nel forum foto esplicative per capire la differenza), in quest'ultimo caso "pretendi" che ti venga pulito in garanzia (in LTR conoscono ormai perfettamente il problema ormai noto su molte D7000).
Aspetta, come ti è stato detto, che passino le feste, magari fino a metà gennaio per evitare che rimanga ferma per ferie e chiusure varie per festività e... naturalmente, in bocca al lupo!
playrick2001
ragazzi scusate, io per inutilizzo dovrei vendere il 70-200 vrII che ho purtroppo sfruttato pochissimo con la D7000, ma nella sezione usato non mi fa inserire inserzioni. Sapete il perchè?
reclinato
QUOTE(playrick2001 @ Dec 12 2011, 07:07 PM) *
perchè per inserire l'usato devi aver registrato almeno una nital card... tu sei uno "user" e deduco che non ne hai registrato nemmeno un prodotto nital... ed ecco svelato l'arcano... smile.gif
prospero
Giacomo.terra
Scusate doppio post poi verrà cancellato...qui ad una miglior risoluzione
IPB Immagine Ingrandimento full detail : 539.9 KB
IPB Immagine Ingrandimento full detail : 536.9 KB
IPB Immagine Ingrandimento full detail : 523.2 KB
tigertank
QUOTE(reclinato @ Dec 12 2011, 05:11 PM) *
prospero
Ciao! Ho preso al volo un 70-200 hsm os usato con 3 mesi scarsi di vita. Per adesso ti pubblico queste prove veloci casalinghe da prima volta fatte ora e a mano libera. Le ho solo ridotte di dimensioni.
A parte il fatto che devo farci il rodaggio, come già sapevo a f2,8 è un pò morbido(il nikon mi sa che imbattibile in questo) ma già a f4 diventa molto più nitido. Credo che quando si ritornerà alle t-shirt dovrò anche prendere una nuova cinghia più morbida biggrin.gif
P.S. Non far caso alle statuine...non sono il massimo della bellezza ma sono un ricordo di famiglia che risale ai miei nonni.
F2.8 + flash
IPB Immagine Ingrandimento full detail : 1.2 MB
F4 + flash
F2.8 senza flash.
playrick2001
che brutta limitazione... grazie della risposta comunque
reclinato
QUOTE(tigertank @ Dec 12 2011, 07:22 PM) *
F2.8 + flash
F4 + flash
F2.8 senza flash.
se devo esser sincero non mi sembra per nulla morbido... tutt'altro... complimenti. chiedo troppo se mi dici il prezzo che ti ha fatto? anche in privato se vuoi...
QUOTE(playrick2001 @ Dec 12 2011, 07:34 PM) *
direi che è abbastanza stupida come cosa... però tant'è...
prospero
aleco76
Di rientro dal ponte ecco qualche scatto di Innsbruck .....
Innsbruck di aleco76, su Flickr
Alessandro
gian189
Ciao ragazzi,
un saluto rapido dalla Turchia ci sentiamo al ritorno (spero con qualche foto decente:)
gian 189
Adriano_86
Qualche scatto autunnale, anche se la stagione è già passata... (località Rocca di Mezzo, AQ).
IPB Immagine Ingrandimento full detail : 2.2 MB
IPB Immagine Ingrandimento full detail : 1.8 MB
Allego anche il relativo video, in buona parte girato con la D7000:
http://www.youtube.com/watch?v=f7CxPHGsY60
nomad77
Clicca per vedere gli allegatiClicca per vedere gli allegati[attachmen
t=164462:DSC_5614_01.JPG]Clicca per vedere gli allegati
trasferta di lavoro a sestri:
cassinet
Io per esperienze personali ( e ne ho un pò ! sigh ) ho sempre mandato sia per scontrino che per nital card soltanto una fotocopia.
Per il resto quoto tutto quello detto da Leo.
bross
Posto qualche scatto, consigli e critiche vi raccomando
IPB Immagine Ingrandimento full detail : 4.5 MB
Casa ecologica
IPB Immagine Ingrandimento full detail : 6.6 MB
IPB Immagine Ingrandimento full detail : 4.1 MB
Mosaico moderno il più grande al mondo nel 2007
IPB Immagine Ingrandimento full detail : 3.8 MB
Mario
bross
Tanto per essere in tema col natale
IPB Immagine Ingrandimento full detail : 9.6 MB
Mario
aleco76
Artista di strada a Innsbruck .......
Artista di strada di aleco76, su Flickr
Alessandro
leo1251
QUOTE(aleco76 @ Dec 13 2011, 06:16 AM) *
http://www.flickr.com/people/colomboalessandro
Alessandro
Bella, ma la nitidezza "puzza" un po' troppo di maschera di contrasto.
bat21
D'altronde, questo forum è Nital.
oraziotp
QUOTE(leo1251 @ Dec 12 2011, 06:11 PM)
2748715[/url]']
Grazie Leo sei sempre gentile. Il sensore sono quasi sicuro che sia sporco di polvere; ho una D80 e mi sembra lo stesso tipo di sporco. Pensavo di inviare la fotocamera subito perché immagino che tutti invieranno le macchine dopo le feste, e per fortuna non ho venduto la D80!
gioton
Credo che dipenda dal fatto che sei un user e non un Nikonista. Tu hai registrato dei prodotti Nital?
Comunque se qualcuno che legge è interessato può mandarti un MP.
Ti mando un MP (per un'altra ragione).
Giorgio
Giacomo.terra
QUOTE(maxray @ Dec 13 2011, 09:18 AM) *
Bellissime Max!...con cosa hai scattato??
Gli iso possibile solo 320?
cunta
bellissime,
posso chiederti che software hai usato x lo sviluppo e se uno in particolare x togliere il rumore? grazie & complimenti ancora
Saluti Fabio
maxray
Innanzitutto grazie ... d7000 (ovvio) + afd 501.4 ... iso auto fino a 6400, metodo di esposizione semispot con decentramento del punto di fuoco a destra o a sinistra ... scattato in Raw ... post pochissima con camera Raw e/o PP cs5 ... tutto qui. wink.gif
elstefano
avendo un 16-85 3.5
e un 50mm di quelli antichi (cioe' messa a fuoco manuale, e settagio apertura a mano).
mi consigliate di andare su un 50 1.8 automatizzato (c'e' il D che viene circa 130caffe').
di buttarmi su un 85 (che pero' avendo il 16-85 nn so se ha senso).
un 35? (mi pare costi un po' tanto)
o altro?
diciamo che a me piace fotografare un po' di tutto (vedi il flickr in firma). ma vorrei buttarmi un po' sui ritratti. poche macro.
reclinato
QUOTE(elstefano @ Dec 13 2011, 11:46 AM) *
avendo un 16-85 3.5
o altro?
il 16-85 è un obiettivo buio... un fisso ti consentirebbe di giocare molto di più con la pdc e di scattare in situazioni limite.
Non è un problema di sovrapposizione di focali ma un problema di cosa vuoi da un fisso...
uso generico? 24,28,35 possono andar più che bene. La scelta dipende da come fotografi (io ho preferito il 24 al 35)
uso geneerico-ritrattistico? prendi il 50 (g mi raccomando), ma personalmente la trovo tronca come focale su dx.
uso ritratto-paesaggio artistico? 85 1.8, la miglior scelta qualità prezzo. Un signor obiettivo, davvero favoloso. è la lente che uso si più.
prospero
Giacomo.terra
avendo un 16-85 3.5
o altro?
elstefano
QUOTE(Giacomo.terra @ Dec 13 2011, 12:06 PM) *
Giacomo.terra
QUOTE(elstefano @ Dec 13 2011, 01:23 PM) *
cingolino
ciao a tutti,
finalmente riesco a postare qualcosa, non ho avuto più tempo.
IPB Immagine Ingrandimento full detail : 1.1 MB
Nutro un vero amore-odio per questi volatili....... è incredibile la difficoltà nel riuscire a scattargli una foto. Sono loto diffidenti!!!!!
Foto scattata vicino a Livorno con il 300 mm dal finestrino dell'auto e già scappava!!!!! Fulmine.gif
Una info, 10 gg fa ho portato la macchina a far pulire il sensore, oggi mi sono accorto che in basso a destra c'è un puntino nero che però non si vede nelle foto, nemmeno a f 22. Da che cosa può dipendere? Voi che faresti? Tenete conto che la prox settimana parto e sicuramente al ritorno ci sarà bisogno della pulizia del sensore. Io sarei per lasciarlo stare così.....voi che dite?
maxray
io il 50 afd 1.4 l'ho pagato 250 euro nuovo su internet ... wink.gif e và da dio.... vedi foto sopra della kick..
il donda
QUOTE(maxray @ Dec 13 2011, 02:41 PM) *
mi puoi dire, in MP, dove?
grazie mille
Riccardo_79
ragazzi sono possessore anch'io della D7000 ma continuo a riscontrare molto rumore a 3200 iso, è cosa normale oppure dovrebbe reggerli bene? mi hanno sempre detto (erroneamente??) che la D7000 regge bene fino a 3200... ma per le mie esperienze direi proprio no..
Che mi dite in merito?
albpat14
Scusate, stamani la 7000 mi ha creato un problema. Dava Err la mpeggiante. Che devo fare? Ho gia provato a rimettere in carica la batteria, a reinserirla, ma il problema persiste.
Grazie a tutti per le risposte.
reclinato
QUOTE(Riccardo_79 @ Dec 13 2011, 03:43 PM) *
ti dico che ho scattato fino a 6400 iso e di rumore ce n'è ben poco per essere una fotocamera aps-c. Il rumore, se esponi male, te lo ritrovi anche a 200 iso, c'è poco da fare. Il segreto è l'esposizione corretta.
Devi cercare di esporre a destra (sovraesposizione), altrimenti se sottoesponi è dura non avere rumore dopo in pp se cerchi di tirar su l'esposizione....
ho caricato più volte degli esempi, se vai indietro li trovi... a parte che giacomo credo abbia pubblicato prprio qualche giorno fa dei jpeg nativi a 3200 iso...
prospero
Giacomo.terra
QUOTE(albpat14 @ Dec 13 2011, 03:47 PM) *
che obbiettivo hai? A volte con vecchi obbiettivi con la ghiera dei diaframmi, se il diaframma non è chiuso al massimo da err...
Prova a guardare
perchè non ci posti qualche foto??
