Pagine: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585, 586, 587, 588, 589, 590, 591, 592, 593, 594, 595, 596, 597, 598, 599, 600, 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615, 616, 617, 618, 619, 620, 621, 622, 623, 624, 625, 626, 627, 628, 629, 630, 631, 632, 633, 634, 635, 636, 637, 638, 639, 640, 641, 642, 643, 644, 645, 646, 647, 648, 649, 650, 651, 652, 653, 654, 655, 656, 657, 658, 659, 660, 661, 662, 663, 664, 665, 666, 667, 668, 669, 670, 671, 672, 673, 674, 675, 676, 677, 678, 679, 680, 681, 682, 683, 684, 685, 686, 687, 688, 689, 690, 691, 692, 693, 694, 695, 696, 697, 698, 699, 700, 701, 702, 703, 704, 705, 706, 707, 708, 709, 710, 711, 712, 713, 714, 715, 716, 717, 718, 719, 720, 721, 722, 723, 724, 725, 726, 727, 728, 729, 730, 731, 732, 733, 734, 735, 736, 737, 738, 739, 740, 741, 742, 743, 744, 745, 746, 747, 748, 749, 750, 751, 752, 753, 754, 755, 756, 757, 758, 759, 760, 761, 762
alcarbo
QUOTE(nippokid (was here) @ Jan 28 2012, 06:53 AM) *
Un passaggio del Faraone guru.gif cool.gif merita/consente un fuori orario rolleyes.gif
da Alcarbo, il Vulcanizzatore di Corte
alcarbo
DEVILMAN 79
Sera a tutti, mi è arrivata la AW 100, non vedo l'ora di giocarci un pò sott'acqua.....
....intanto la batteria carica e io leggo il manuale.
Vincenzo.
Cary
alcarbo
davidebaroni
In attesa di capire se piove o nevica...
DEVILMAN 79
Sera a tutti, io vado a birra stasera, la signora si è messa sul divano con la AW100 e stà divorando il manuale.....
.....che sia la volta buona che si appassiona alla fotografia??? Speriamo.
Vincenzo.
Cary
Hola!
QUOTE(davidebaroni @ Feb 1 2012, 12:10 AM) *
IPB Immagine Ingrandimento full detail : 451.5 KB
QUOTE(DEVILMAN 79 @ Feb 1 2012, 12:45 AM) *
Vincenzo.
DEVILMAN 79
QUOTE(Cary92 @ Feb 1 2012, 12:50 AM) *
Quella non le piace, col BG sempre montato la trova troppo pesante, poi ha paura di sprecare pellicola e la evita..... la D90 invece la usa, ed ha anche un ottimo occhio...
Vincenzo.
Cary
QUOTE(DEVILMAN 79 @ Feb 1 2012, 02:04 AM) *
Vincenzo.
alcarbo
Buon..........
valeam
Sono giorni che giro per il sito Nital alla ricerca di un posto dove mandare una mail con la speranza di ottenere una risposta.
Sono sempre stato un fedelissimo Nital. Ho quindici prodotti registrati dal 2008. Corpi reflex, obiettivi, flash e diverse Coolpix. Purtroppo dopo la riparazione la D90 mi è stata rimandata indietro senza batteria. Mi domando a questo punto se non sia il caso di rivedere la fiducia in Nital
e cercare i prossimi prodotti Nikon sul web, al prezzo più basso e confidare sulla garanzia europea o pagare direttamente le eventuali riparazioni.
alcarbo
Io non so darti una risposta
E' troppo amletico come dubbio, per quest'ora della mattina
Sorry.
p.s. ci sono già tante discussioni, ma le avrai già viste
QUOTE(valeam @ Feb 2 2012, 12:24 AM) *
hai già contato la LTR? La riparazione la fatta fare da loro?
La Nital è da tempo che non ha un Email pubblica, i problemi con la clientela vengono risolti tramite il call center, se proprio vuoi scrivere devi farlo alla vecchia maniera....con tanto di francobollo, l'indirizzo "fisico" della Nital lo trovi qua:
http://www.nital.it/contatti/index.php
SkZ
In verita' dalla sede a La Serena, su non ci sono ancora andato.
ciao nippo ohmy.gif passi ancora!
Cary
Ciao SkZ!
QUOTE(SkZ @ Feb 3 2012, 01:44 AM) *
alcarbo
DEVILMAN 79
Sera a tutti, nottata da lupi, sottozero e nemmeno un fiocco di neve......
Vincenzo.
Cary
Buonasera!
alcarbo
davidebaroni
Buonasera1
Io intanto vado a dormire, e vediamo quanto vi portate avanti voi con il "lavoro"! messicano.gif
alcarbo
mbbruno
buona notte amici nottambiuli
alcarbo
Cary
Hola!
lhawy
veramente avresti dovuto mandarla tu senza! almeno mi pare così richiedano in ltr.
buona notte!
alcarbo
Ragazzi mi sa che avete sbagliato sezione. Dovevate andare in Help.
Qui si parla solo di cose futili, ed è per questo che la discussione che ha più post di tutto il forum. wink.gif
davidebaroni
QUOTE(alcarbo @ Feb 15 2012, 05:28 AM) *
DEVILMAN 79
Buonasera a tutti....
Vincenzo.
Cary
Buonasera...
-syd-
c'e' nessuno ? mi va una berretta!! partitina a carte intanto ??
Immagine ridimensionata: clicca sull'immagine per vederla con le dimensioni originali. Ingrandimento full detail : 72.7 KB
DEVILMAN 79
'sera a tutti....
Un pokerino ci stà bene, per la birra passo, dopo una cena col suocero a lardo di colonnata e negramaro, sarebbe il colpo di grazia....
Vincenzo.
-syd-
QUOTE(DEVILMAN 79 @ Feb 20 2012, 01:24 AM) *
'sera a tutti....
Vincenzo.
uuuu ... lardo di colonnata ... pensa che sono di Massa Carrara .... :-)
QUOTE(-syd- @ Feb 20 2012, 01:05 AM) *
La berretta te la posso dare io
davidebaroni
Aperto anche stasera... per me, camomilla, tripla e con un limone intero spremuto dentro, grazie! smile.gif
Cary
Hola!
Serata passata al telefono (meno di 5 minuti, ma molto tesi XD) e poi con alcuni amici biggrin.gif
Ciao Davide!
QUOTE(davidebaroni @ Feb 20 2012, 11:33 PM) *
Tu apri..
e io vo' al letto!!!!
Cary
alcarbo
davidebaroni
Cary
buonasera.
Enrico_Luzi
un saluto a tutti!
Voi dormite e io lavoro
MrFurlox
QUOTE(Enrico Luzi @ Feb 23 2012, 12:46 AM) *
un saluto a tutti!
alcarbo
Ho raggiunto il post 8000 e così ho esaurito quelli per me disponibili.
Ora posso solo postare al Bar, dove non vengono conteggiati e numerati. Ciao
alcarbo
Ho mancato alla promessa.
Dormite tranquilli.
SkZ
Interessante si: devo aiutare al comissioning di una camera infrarossa con pixel scale 0.02''/pxl (generalmente e' dieci volte superiore).
Per puntare il telescopio dobbiamo usare il catalogo preparato per il nuovo telescopio spaziale. Ottica Adattiva che usa 5 fasci laser per creare stelle artificiali.
mbbruno
http://www.youtube.com/watch?v=0umCKG4j2-U
vi saluto cosi
0emanuele1
http://it.wikipedia.org/wiki/Insonnia
Cary
Hola...
Ciao Emanuele.
0emanuele1
