Pagine: 1, 2, 3, 4, 5
primoran
QUOTE(gianpiero.lui @ Jun 13 2009, 08:47 PM) *
Uso WINDOWS XP SP3 con tutti gli update, l'upgrade a NX 2.2.1 non mi funziona
Si apre pagina pop-up con il seguente messaggio, fin dall apertura del file NEF
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.OverflowException: Overflow error.
at System.Drawing.Graphics.CheckErrorStatus(Int32 status)
at System.Drawing.Graphics.DrawImage(Image image, Rectangle destRect, Int32 srcX, Int32 srcY, Int32 srcWidth, Int32 srcHeight, GraphicsUnit srcUnit, ImageAttributes imageAttrs, DrawImageAbort callback, IntPtr callbackData)
at System.Drawing.Graphics.DrawImage(Image image, Rectangle destRect, Int32 srcX, Int32 srcY, Int32 srcWidth, Int32 srcHeight, GraphicsUnit srcUnit, ImageAttributes imageAttr, DrawImageAbort callback)
at System.Drawing.Graphics.DrawImage(Image image, Rectangle destRect, Int32 srcX, Int32 srcY, Int32 srcWidth, Int32 srcHeight, GraphicsUnit srcUnit, ImageAttributes imageAttr)
at System.Windows.Forms.ControlPaint.DrawImageDisabled(Graphics graphics, Image image, Rectangle imageBounds, Color background, Boolean unscaledImage)
at System.Windows.Forms.ControlPaint.DrawImageDisabled(Graphics graphics, Image image, Int32 x, Int32 y, Color background)
at nik.Windows.Forms.LevelAndCurves.GradientSliderControl.OnPaint(PaintEventArgs e)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Capture NX 2
Assembly Version: 2.2.1.32468
Win32 Version: 2, 2, 0, 0
CodeBase: file:///C:/Programmi/Nikon/Capture%20NX%202/Capture%20NX%202.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
NxController
Assembly Version: 2.2.0.28161
Win32 Version: 2.2.0.0
CodeBase: file:///C:/Programmi/Nikon/Capture%20NX%202/NxController.DLL
nik.GUIBase
CodeBase: file:///C:/Programmi/Nikon/Capture%20NX%202/nik.GUIBase.DLL
GUI_Common_Managed
Win32 Version:
CodeBase: file:///C:/Programmi/Nikon/Capture%20NX%202/GUI_Common_Managed.DLL
msvcm80
Assembly Version: 8.0.50727.1433
Win32 Version: 8.00.50727.1433
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1433_x-ww_5cf844d2/msvcm80.dll
nik.Base
CodeBase: file:///C:/Programmi/Nikon/Capture%20NX%202/nik.Base.DLL
nik.GUIBase.Resources
Win32 Version:
CodeBase: file:///C:/Programmi/Nikon/Capture%20NX%202/nik.GUIBase.Resources.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
as0l03xp
yzv_idst
NxCursors
CodeBase: file:///C:/Programmi/Nikon/Capture%20NX%202/NxCursors.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Ciao, non che mi faccia piacere, ma tu sei messo peggio di me.
Almeno io reinstallando la versione 2.0 adesso mi funziona tutto.
Speriamo che lo staff Nital possa risolvere il nostro problema.
Anche perch� � un SW che costa!!
Primo.
cibgiu
X gianpiero.lui: ho notato che hai dei files del net framework non aggiornati, prova ad installare questo NetFx20SP2_x86.exe
da http://www.microsoft.com/downloads/details...1d-10e506da9d0f e NDP20SP2-KB958481-x86.exe da http://www.microsoft.com/downloads/details...54-6450b0212565
Ciao, Giuseppe
gianpiero.lui
QUOTE(cibgiu @ Jun 13 2009, 11:55 PM) *
X gianpiero.lui: ho notato che hai dei files del net framework non aggiornati, prova ad installare questo NetFx20SP2_x86.exe da.............
hai ragione, gli aggiornamenti automatici non me lo propongono,
ma nella lista degli "installati" non c'�.
Ci provo ( non subito) e rilascio l'esito a breve
gianpiero.lui
NX 2.2.1 funzionante. I precedenti errori sono spariti
PERO' ora la novit� rilevata � che, al tentativo di verificare gli aggiornamenti, il Nikon Message Center" mi dice bugie:
"Non � presente una connessione di rete. Stabilire una connessione e riprovare" mad.gif
cibgiu
QUOTE(gianpiero.lui @ Jun 20 2009, 12:41 AM) *
Bene
l'unica cosa che mi viene in mente � che un firewall o programma di protezione blocca la connessione ad internet del nikon message center. Se uno di questi programmi installati verificane la configurazione.
Ciao, Giuseppe
bergat@tiscali.it
Scusa a cosa ti serve la connessione di rete per l'nx2?
Solo per gli aggiornamenti, e a mio avviso tanto vale disinstallare nikon message center, anzi � meglio molto meglio.
gianpiero.lui
@cibgiu
Il fatto � che non uso firewall su PC, ce l'ho solo sul router.
Il fenomento non si presenta n� si � presentato con alcun programma finora.
N� con le precendeti versioni di Capture NX
Dovrei conoscere la porta utilizzata per fare una verifica, ma dubito di risolvere, dato che nulla � bloccato e, quando le "richieste" di connessione partono dal PC, il router � abituato a passarle sia in entrata che uscita
QUOTE("bergat")
Scusa a cosa ti serve la connessione di rete per l'nx2? Solo per gli aggiornamenti, e a mio avviso tanto vale disinstallare nikon message center, anzi � meglio molto meglio.
sono d'accordo, mi � comodo solo controllare aggiornamenti manualmente dall'interno del programma
Piuttosto aggiungo che ho cantato vittoria troppo presto, NX 2.2.1 mi restituisce errore nuovamente Torno alla versione precedente mad.gif
grazie, ciao
bergat@tiscali.it
Quel programma non fa solo quello.... e rimane attivo sempre quando usi nx2, inibendo spesse volte l'utilizzo di NX2......
gianpiero.lui
anch'io non lo tenevo tra le appls prima degli ultimi episodi di "installa e disinstalla"
Lo tolgo, per� resto alla NX V. 2.0.0 : son stufo di smaccanare il PC dry.gif
praticus
.......cut.....
QUOTE(gianpiero.lui @ Jun 21 2009, 10:03 PM) *
.....cut......
....perch� rimanere alla 2.0 se la release 2.2.1 � funzionante grazie all'aggiornamento di XP?
Paolo66
QUOTE(praticus @ Jun 22 2009, 09:11 AM) *
grazie, ciao
A proporsito, nessuna nuova?
gianpiero.lui
QUOTE("praticus")
rispondo a praticus quotando Paolo,
che a sua volta leggendo poco pi� su mi ha quotato smile.gif :
la 2.0 mi gira bene e discretamente rapida, per il mio volume di lavoro pe rora mi arrangio.
Fra 2 mesi acquisto PC nuovo e si vedr�
ciao, grazie per l'interessamento
LucaPetralia
ciao a tutti, credo sia il mio primo messaggio qui. Ho scaricato la trial della 2.2.0 ed ho i problemi riscontrati da gianpiero.lui
mscorlib
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
Capture NX 2
Assembly Version: 2.2.0.31924
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
System
System.Drawing
NxController
Assembly Version: 2.2.0.27150
nik.GUIBase
nik.Base
GUI_Common_Managed
Win32 Version:
msvcm80
Assembly Version: 8.0.50727.3053
Win32 Version: 8.00.50727.3053
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca/msvcm80.dll
Win32 Version:
System.Xml
tfvhacoe
ul9gc6gm
NxCursors
enabled.
For example:
<configuration>
</configuration>
Ho scaricato il framework 2.0 e l'aggiornamento sicurezza, come indicato sopra, ma nada...
Mi sapreste indicare dove pescare la versione 2.0 trial per eventualmente provare?
Ho ricevuto l'nx2 in promozione con la D700 e prima di installarlo ed attivarlo vorrei provare se per me che sono abituato con lightroom ne vale la pena o no
cibgiu
QUOTE(LucaPetralia @ Jul 23 2009, 12:30 PM) *
hai dei messaggi errore o altro che ci pu� aiutare a capire dove pu� essere il problema?
Purtroppo ci sono varie componenti in gioco - sw Nikon, componenti di base del s.o., componenti aggiuntivi, ecc. - e pu� capitare che con versioni non allineate escano gli errori.
Non sapendo cosa hai installato/aggiornato ti suggerisco di installare questi:
1) http://www.microsoft.com/downloads/details...cf-a7633f706ba5
2) http://www.microsoft.com/downloads/details...19-81da479ab0d7
Prova....male non fa al pc.
Facci sapere.
Ciao, Giuseppe
LucaPetralia
QUOTE(cibgiu @ Jul 23 2009, 01:44 PM) *
Facci sapere.
Ciao, Giuseppe
l'errore me lo da in apertura della foto e mi dice errore di overflow
Eccezione non gestita ecc.
Dopo di che se clicco sui dettagli dell'errore appare la lista specificata nel post precedente. Ho installato i framework ma niente, ho ridotto le dimensioni della cache di NX e niente ancora
primoran
QUOTE(LucaPetralia @ Jul 23 2009, 08:25 PM) *
Ciao, a me i problemi si sono risolti dopo l'installazione del SP2 di Vista e del codec
S-NEFCDC-170WF-ALLIN.exe. Come potrai verificare da alcuni miei interventi sul
forum avevo grosse rogne. Adesso tutto fila alla perfezione.
Ciao, Primo
LucaPetralia
il fatto � che ho XP sp3 e vista non voglio nemmeno vederlo col binocolo
cibgiu
puoi allegare la tua lista con l'errore? li sono presenti le versioni dei componenti e cos� le posso verificare con le mie dove capture nx 2.2.1 funziona senza problemi
Ciao, Giuseppe
Sembrerebbe il problema che utilizzano XP SP3.
Io, ad esempio, ho comprato un netpc con XP SP3, installato NX2 e, ovviamente, velocit� a parte, non riscontro alcun problema.
Installato NX2 sul vecchissimo desktop a casa, riscontro lo stesso errore.
Percui, mi d� da pensare che ci sia qualcosa che in alcuni PC non d� problemi mentre in altri s�.
Hai provato a formattare l'HD ed installare NX2 subito dopo? Sul mio NetPC ho eseguito l'installazione su SO pulito e tutto, come dicevo prima, funziona regolarmente.
P.S.: Non capisco tutta questa avversione per Vista. Io ce l'ho sul portatile e non ho mai, dico mai riscontrato alcun problema. Riesco a far girare anche programmi che, teoricamente, non potrebbero.
Comunque, il prossino SO di Microsoft sembrerebbe mooolto buono.
LucaPetralia
QUOTE(cibgiu @ Jul 23 2009, 11:50 PM) *
Ciao, Giuseppe
La lista degli errori l'ho inserita nel primo messaggio, quello a cui hai risposto.
Non ho provato a formattare anche perch� tutto sommato la formattazione � piuttosto recente
Per l'avversione a vista beh...l'ho trovato quanto di pi� contorto possa esistere, e non � che sono il primo xxx che ha a che fare coi pc. Su pc pi� potenti del mio riesce ad avere prestazioni peggiori del mio XP SP3. Ergo ho deciso di lasciar perdere. Cosa che probabilmente far� con NX2, dato che non posso permettermi giornate intere per stare appresso ad un software. Continuer� con Lightroom, come ho sempre fatto
cibgiu
QUOTE(LucaPetralia @ Jul 24 2009, 09:50 AM) *
ho controllato le versioni e mi sembrano aggiornate.
Prova a mettere la 2.2.1 di capture nx2
Una curiosit�: hai il doppio monitor? se si, puoi provare a passare in modalit� monitor singolo.
Non so se c'entra, ma io sui miei pc hi anche i framework 1, 3 e 3.5
Ciao, Giuseppe
P.S. vi ricordate quando si � passti da Windows 3.x a Windows 95 e/o da Windows NT/2000 a Windows XP? sono state fatte le stesse critiche che si fanno oggi con Vista...a breve finiranno perch� sta per uscire Windows 7 messicano.gif
nippokid (was here)
Aggiornamento di Capture NX 2.2.2 - Windows - Macintosh
