Zeiss Introduces ZF-I Lens Series
OBERKOCHEN/Germany, 06.11.2007. What professional photographers feel enthusiastic about we at Carl Zeiss do not want to keep from other users of lenses for technical applications. With the new ZF-I series, Carl Zeiss has launched a line of high-quality lenses which are optimized for the challenging tasks in industrial applications.
The imaging properties of the ZF-I lenses are just as excellent as those of the high-end ZF lenses. The silver metal finish immediately identifies the industrial version. Furthermore, the ZF-I series is particularly suitable for rough technical applications. The lenses are protected against spray water and specially sealed against dust.
In addition to classical image capturing, the new lenses can also be used for machine vision, quality assurance and near-range photogrammetry. Both the aperture setting and focus can be locked for these tasks. For this purpose, the lenses are supplied with five locking screws which enable reliable locking of the adjustments once they have been set. Measuring inaccuracies and errors are thus reduced, and there is no need to waste time checking the settings.
The first lenses available in this new industrial line are the wide-angle Distagon T* 2,8/25 ZF-I, Distagon T* 2/28 ZF-I and the Distagon T* 2/35 ZF-I. All lenses offer the proverbial imaging performance and color fidelity associated with the ZEISS standard and feature the F-bayonet – the most commonly used standard camera adapter in the technical area.
Sono lenti con un trattamento speciale per la polvere e gli spruzzi d'acqua e con un controllo manuale della taratura del diaframma e della messa a fuoco.
