giuliomagnifico
Praticamente � un sensore non a matrice di Bayer (pi� simile al Foveon) nel quale Sony, stando a questo brevetto, ha implementato un vetro davanti al sensore che corregge la caduta di qualit�/luce ai bordi. ...da seguire!
Innovative Sony multilayer sensor patent shows how to get rid of corner issues.
The short E-mount flange distance has one �drawback�. Lenses have to be larger to correct the incident angle at the corner which usually causes heavy color shifting, huge vignetting and loss of sharpness. That�s why Voigtlander redesigned the Heliar 15mm III lens (here on eBay). And the new design makes the new lenses twice as big as the predecessor.
Sony seems to have acknowledged that there is an issue to be solved. Egami spotted a new Sony sensor which packs a couple of innovations. First of all this is a multilayered sensor (and not a classic RGB Bayer). And the second innovation is that there is a lens on the sensor that corrects the angle of the light hitting the sensor. With that solution the light hits the full sensor with the right angle. It would allow lenses to be more compact because they don�t have to uses more glass to correct the angle.
On paper it would also allow all third-party lenses (particularly wide-angle lenses) to work flawlessly on Sony FE cameras. Let�s hope the next generation FE camera will come with such a sensor. Exciting!
http://www.sonyalpharumors.com/innovative-...-corner-issues/
riccardobucchino.com
� molto utile per fotocamere con tiraggio corto e sensore grande come le sony A7, le leica m etc, sulle nostre nikon sicuramente pu� dare benefici ma non molti visto che corregge un problema in gran parte corretto dalla scelta di un tiraggio maggiore.
rolubich
QUOTE(riccardobucchino.com @ Apr 4 2015, 12:43 AM) *
Forse Nikon potrebbe ritornare a fare dei grandangoli che non siano lunghi come dei tele. smile.gif
pes084k1
QUOTE(giuliomagnifico @ Apr 3 2015, 08:49 PM) *
L'errore della Sony A7r � essenzialmente uno spostamento dei pixel laterali, correggibilissimo in demosaicing con il software giusto e con MAF da superwide. Molte prove sono state fatte con ottiche superwide in condizioni non opportune o sbagliate tecnicamente: per esempio il Voigt 15 mm LTM (che ho) ha una curvatura di campo spiccata e un cast ANCHE SUL FILM ed � ottimizzato per distorsione e prospettive con soggetto al centro e fughe laterali. Lo ZM21C e gli ultimi Heliar VM 15 II (ne ho uno di entrambi) hanno color cast spianabile, ma la nitidezza si estende con soggetto piano fino al bordo. Ho visto dei test "suicidi" con il 15 VM II (non so se quelli iniziali o modificati) con soggetto all'infinito e MAF su "iperfocale" invece, gente dedita solo ad ingannare s� stessa e gli altri. La CA da rifrazione non corretta poi su Imatest & C. viene vista come sfocatura. Dopo un corretto sviluppo raw � tutto OK, almeno al livello teorico e contro le reflex: un 15 mm al bordo deve perdere met� della risolvenza al cento con una PSF oblunga (quindi MTF sagittale moltobassa...) senza distorsione.
Il nuovo Heliar corregge le fringe, non la nitidezza "reale" ed � distorto, quindi ricorreggendo...
E' ovvio che se avessimo un pixel segmentato per registrare da vari angoli di incidenza (Lytro!!) potremmo correggere di botto anche strani astigmatismi, non questi qua. Il sensore Sony nuovo comunque sarebbe poco flessibile, poco sensibile, richiederebbe comunque un demosaicing ad hoc per ottiche non wide.... sarebbe un film replacement, ma con lo svantaggio che la luce passa pi� facilmente sotto la gelatina che attraverso silice in forma cristallina (una forma amorfa � il vetro...).
Elio
