MarcoD5
Provatea scaricare la versione beta, attenzione si tratta di versione prova, non affidate lavori finiti
Nuova ACR 8.5 Adobe Photoshop
giulysabry
QUOTE(marcomc76 @ Jun 5 2014, 11:51 AM) *
Occhio che � solo per il Creative Cloud...
stefanoc72
Features
Modify Graduated and Radial Filter masks with a brush:
After adding or selecting a Graduated or Radial Filter instance, click the new 'Brush' mode (next to existing 'New' and 'Edit' mode buttons) to reveal brush controls that allow you to modify the selected mask.
Use the 'Brush +' and 'Brush -' icon buttons in the brush controls pane to add to or erase from the selected mask.
Press the 'Clear' button to remove all brush modifications from the currently selected mask.
When a Graduated or Radial Filter instance is selected, Shift-K can be used to enter and leave brush modification mode.
Mask visualization is now available for the Graduated and Radial Filters. Use the Mask checkbox at the bottom of the Local Corrections pane or press 'Y' to toggle the mask overlay.
Added new Per-Panel Preview default toggle
If the current panel's settings are not the ACR defaults, clicking the new Per-panel Toggle Button will reset the panel to the ACR defaults.
Clicking the button again will restore the previous settings.
This is a standalone feature, separate from the new Preview controls
The changes are applied to the main view; if you have both the Before and After panes visible, changes will appear in the After pane.
Bug Fixes
Fixed issue with Fujifilm X-T1 raw images appearing too bright at high ISO settings when using Dynamic Range 200% and 400%. Unfortunately, this fix may affect the appearance of existing images captured with this combination of settings. It is recommended that you (1) purge the Camera Raw cache via the Camera Raw Preferences dialog, and (2) review images shot at ISO settings higher than 1600 for unexpected brightness changes.
Fixed image quality issue (noisy result) when applying spot healing to floating-point (HDR) images.
Fixed issue with reading lossless compressed Nikon raw files (NEF files) from the camera models listed below. Previously, some images could be read but would appear as random noise, whereas attempting to open others would result in an error dialog. You will need to purge your Camera Raw cache via the Camera Raw Preferences dialog.
Nikon D1
Nikon D1H
Nikon D1X
Nikon D2H
Nikon D2Hs
Nikon D2X
Nikon D2Xs
Nikon D100
Nikon D200
New Camera Support
Canon PowerShot G1 X Mark II
Fuji FinePix S1
Nikon 1 J4
Nikon 1 V3
Olympus OM-D E-M10
Panasonic LUMIX DMC-GH4 (*)
(*) denotes preliminary support
New Lens Profile Support
Lens Name Lens Mount
Sigma 50mm F1.4 DG HSM A014 Canon
Sigma 18-200mm F3.5-6.3 DC MACRO OS HSM C014 Canon
Tamron 16-300mm F3.5-6.3 DiII VC PZD MACRO B016E Canon
Fujifilm Tele Conversion Lens TCL-X100 Fuji
Nikon 1 NIKKOR VR 10-30mm f3.5-5.6 PD-ZOOM Nikon
Nikon AF-S DX NIKKOR 18-300mm f/3.5-6.3G ED VR Nikon
Sigma 50mm F1.4 DG HSM A014 Nikon
Sigma 18-200mm F3.5-6.3 DC MACRO OS HSM C014 Nikon
Tamron 16-300mm F3.5-6.3 DiII VC PZD MACRO B016N Nikon
Tamron SP 150-600mm F5-6.3 Di VC USD A011N Nikon
Sigma 30mm F1.4 DC HSM A013 Pentax
Sigma 50mm F1.4 DG HSM A014 Sigma
Sigma 18-200mm F3.5-6.3 DC MACRO OS HSM C014 Sigma
Sigma 30mm F1.4 DC HSM A013 Sony Alpha
