Questo è uno script che, se usato da Photoshop ad esempio, ti scrive alcuni dati presi dagli exif direttamente nella cornice dello scatto...
studialo un pò e fanne ciò che vuoi...
spero di esserti stato utile....
CODE
// Caption constants. Change these if you want to.
// Copyright string
c_CaptionCopyright = "Copyright © Giorgio Baruffi";
c_CaptionFont = "Verdana";
// Caption text
c_CaptionGpsPrefix = "Luogo:"
c_CaptionDateTimeTaken = "Data scatto:"
c_CaptionModel = "Macchina:"
c_CaptionExposureTime = "Tempo:"
c_CaptionAperture = "Apertura:"
c_CaptionFocalLength = "Focale:"
c_CaptionIsoRating = "ISO:"
// Date and time constants. Change these if you want to.
c_MonthsArray =
"Gen",
"Feb",
"Mar",
"Apr",
"Mag",
"Giu",
"Lug",
"Ago",
"Set",
"Ott",
"Nov",
"Dic"
c_AM = "am"
c_PM = "pm"
// Colors
function CreateSolidRgbColor(r, g, b)
var result = new SolidColor;
result.rgb.red = r;
result.rgb.green = g;
result.rgb.blue = b;
return result;
var colorCaptionBackground = CreateSolidRgbColor(255, 255, 255);
var colorFrame = CreateSolidRgbColor(0, 0, 0);
var colorText = CreateSolidRgbColor(0, 0, 0);
// Include EXIF constants and methods.
// Note the this is not a comment: it includes the contents
// of ExifHelpers.inc in this script!
//@include "ExifHelpers.inc"
// Functions
// Photoshop CS formats the latitude and longitude strings
// oddly:
// Example: 47.00 38.00' 33.60"
// There is no degrees symbol after the degrees, and
// they leave useless zeroes on the right side of the decimal
// point for both degrees and minutes. This function parses
// the numbers from the latitude and longitude strings, and
// inserts the correct characters where they belong:
// Example: 47° 38' 33.6"
// It returns an empty string if the string is in an unexpected
// form or doesn't exist.
function CorrectlyFormatLatitudeOrLongitude(strLatLong)
var strResult = new String("");
// Copy the input string
var strSource = new String(strLatLong);
// Find the first space
nIndex = strSource.indexOf(" ");
if (nIndex >= 0)
// Copy up to the first space
strDegrees = strSource.substr(0, nIndex);
// Skip this part, plus the space
strSource = strSource.substr(nIndex + 1);
// Find the tick mark
nIndex = strSource.indexOf("'");
if (nIndex >= 0)
// Copy up to the tick mark
strMinutes = strSource.substr(0, nIndex);
// Skip this chunk, plus the tick and space
strSource = strSource.substr(nIndex + 2);
// Find the seconds mark: "
nIndex = strSource.indexOf("\"");
if (nIndex >= 0)
// Copy up to the seconds
strSeconds = strSource.substr(0, nIndex);
// Get rid of extraneous trailing zeroes
var nDegrees = parseFloat(strDegrees);
var nMinutes = parseFloat(strMinutes);
var nSeconds = parseFloat(strSeconds);
// Use the correct symbols
strResult = nDegrees.toString() + "° " + nMinutes.toString() + "' " + nSeconds.toString() + "\"";
return strResult;
// This function gets the GPS location fields and formats them correctly
// It returns an empty string if they don't exist
function GetFormattedGpsData()
// Get the fields
strLatitude = GetRawExifValueIfPresent(c_ExifGpsLatitude);
strLatitudeRef = GetRawExifValueIfPresent(c_ExifGpsLatitudeRef);
strLongitude = GetRawExifValueIfPresent(c_ExifGpsLongitude);
strLongitudeRef = GetRawExifValueIfPresent(c_ExifGpsLongitudeRef);
// Do all of them exist?
if (strLatitude.length && strLatitudeRef.length && strLongitude.length && strLongitudeRef.length)
// Parse and reformat the latitude and longitude
strFinalLatitude = CorrectlyFormatLatitudeOrLongitude(strLatitude);
strFinalLongitude = CorrectlyFormatLatitudeOrLongitude(strLongitude);
// Are they still valid?
if (strFinalLatitude.length && strFinalLongitude.length)
// Create the result (with the constant prefix)
strResult = c_CaptionGpsPrefix + " " + strFinalLatitude + " " + strLatitudeRef + ", " + strFinalLongitude + " " + strLongitudeRef;
return strResult;
// EXIF dates are formatted kind of funny, with colons
// between the date tokens:
// Example: 2005:04:13 16:22:47
// This function parses the numbers out of the string
// and formats it like this:
// Example: Apr 13, 2005 4:22:47 pm
function CorrectlyFormatDateAndTime(strDateAndTime)
var strSource = new String(strDateAndTime);
// Find the first colon
nIndex = strSource.indexOf(":");
if (nIndex >= 0)
strYear = strSource.substr(0, nIndex);
// Skip past the colon
// Find the next colon
if (nIndex >= 0)
// Copy up to colon
strMonth = strSource.substr(0, nIndex);
// Skip the colon
// Find the next space
if (nIndex >= 0)
// Copy up to the space
strDay = strSource.substr(0, nIndex);
// Skip the space
if (nIndex >= 0)
// Save the hours
strHours = strSource.substr(0, nIndex);
// Skip the colon
if (nIndex >= 0)
// Save the minutes
// Skip the colon
// Save the seconds
strSeconds = strSource;
// Assume it is AM
strAmPm = c_AM;
// Is it after noon?
if (strHours >= 12)
// Use PM
strAmPm = c_PM;
// If it is after 13:00, subtract 12
if (strHours >= 13)
strHours -= 12;
// If it is 12:xx AM, make it 12:xx instead of 00:xx
else if (strHours == 0)
strHours = 12;
// Format the string
strResult = parseInt(strDay).toString() + " " + c_MonthsArray[parseInt(strMonth) - 1] + ", " + strYear + " " + parseInt(strHours).toString() + ":" + strMinutes + ":" + strSeconds + " " + strAmPm;
return strResult;
// If the value is not an empty string, prepend
// a caption and return the result
function GetPrefixedValue(strCaption, strValue)
if (strValue.length)
strResult = strCaption + " " + strValue;
return strResult;
// Get a simple EXIF property that doesn't need reformatting
// and prepend its title if the value is present
function GetPrefixedSimpleProperty(strCaption, strExifField)
return GetPrefixedValue(strCaption, GetRawExifValueIfPresent(strExifField));
// Format the date and time
function GetFormattedDateTimeTaken()
return GetPrefixedValue(c_CaptionDateTimeTaken, CorrectlyFormatDateAndTime(GetRawExifValueIfPresent(c_ExifDateTimeOriginal)));
// Get the model name of the camera.
// Unfortunately, there is little consistency for EXIF makes and models.
// For example, the Nikon Coolpix 990 looks like this:
// E990
// While the D2x looks like this:
// NIKON D2X
// If your camera has a user-unfriendly name, you might want to modify
// this function to return a user-friendly name.
function GetFormattedModel()
return GetPrefixedSimpleProperty(c_CaptionModel, c_ExifModel)
// EXIF exposure time
function GetFormattedExposureTime()
return GetPrefixedSimpleProperty(c_CaptionExposureTime, c_ExifExposureTime);
// EXIF f-Stop
function GetFormattedAperture()
return GetPrefixedSimpleProperty(c_CaptionAperture, c_ExifAperture);
// EXIF focal length
function GetFormattedFocalLength()
return GetPrefixedSimpleProperty(c_CaptionFocalLength, c_ExifFocalLength);
// EXIF ISO rating
function GetFormattedIsoRating()
return GetPrefixedSimpleProperty(c_CaptionIsoRating, c_ExifIsoSpeedRating);
// If strValue is not empty, add it to the array
function AddAvailableExifFieldToArray(availableFieldsArray, strValue)
// If we have a string, add it to the end of the array
if (strValue.length > 0)
availableFieldsArray[availableFieldsArray.length] = strValue;
// Extract the year from the EXIF date-taken
function GetYearFromDateTaken()
// Get the EXIF date taken
var strSource = GetRawExifValueIfPresent(c_ExifDateTimeOriginal);
if (strSource.length)
if (nIndex >= 0)
// Copy up to the first colon
strResult = strSource.substr(0, nIndex);
// If we don't have a string, use today's date
if (strResult.length == 0)
strResult = ((new Date()).getYear() + 1900).toString();
return strResult;
// Format the copyright string
function GetFormattedCopyright()
// Start with the copyright string
var strResult = new String(c_CaptionCopyright);
// Get the year
var strYear = GetYearFromDateTaken();
if (strYear.length != 0)
// Append it (after a comma and a space)
strResult += ", " + strYear;
return strResult;
// Get all of the interesting EXIF fields, format them, and put them in a comma
// separated string for display.
function GetAllAvailableFields()
// Add all of the fields to the array
var AvailableFields = new Array;
AddAvailableExifFieldToArray(AvailableFields, GetFormattedModel());
AddAvailableExifFieldToArray(AvailableFields, GetFormattedExposureTime());
AddAvailableExifFieldToArray(AvailableFields, GetFormattedAperture());
AddAvailableExifFieldToArray(AvailableFields, GetFormattedFocalLength());
AddAvailableExifFieldToArray(AvailableFields, GetFormattedIsoRating());
AddAvailableExifFieldToArray(AvailableFields, GetFormattedGpsData());
AddAvailableExifFieldToArray(AvailableFields, GetFormattedDateTimeTaken());
// Turn it into one big string
var strResult = new String;
for (nCurrentEntry = 0; nCurrentEntry < AvailableFields.length; ++nCurrentEntry)
if (nCurrentEntry != 0)
strResult += ", ";
strResult += AvailableFields[nCurrentEntry];
return strResult;
// Begin script
function Main()
if (app.documents.length > 0)
// Save the old background color and ruler units
var oldRulerUnits = preferences.rulerUnits;
var oldBackgroundColor = backgroundColor;
try
// Turn off dialog boxes
displayDialogs = DialogModes.NO;
// Use inches for our scale
preferences.rulerUnits = Units.INCHES;
// Decide which axis is longer
var nLongAxis = (activeDocument.height.value > activeDocument.width.value) ? activeDocument.height.value : activeDocument.width.value;
// Calculate the border thickness
var nBorderThickness = nLongAxis / 400;
// How big do we want the font?
var nFontHeight = nLongAxis / 70;
// Calculate the text area height
var nTextAreaHeight = nFontHeight * 3;
// Convert the font size to points
var nFontHeightInPoints = nFontHeight * 72;
// Add the frame
backgroundColor = colorFrame;
activeDocument.resizeCanvas(activeDocument.width.value + nBorderThickness*1, activeDocument.height.value + nBorderThickness*1, AnchorPosition.MIDDLECENTER);
// Save the bottom of the image frame before we add the caption area
var nBottomOfFrame = activeDocument.height.value;
// Add the caption area
backgroundColor = colorCaptionBackground;
activeDocument.resizeCanvas(activeDocument.width.value, activeDocument.height.value + nTextAreaHeight, AnchorPosition.TOPCENTER);
// Create the caption ("\u000D" is a new-line)
var strCaption = GetFormattedCopyright() + "\u000D" + GetAllAvailableFields();
// Create the text layer
var newTextLayer = activeDocument.artLayers.add();
newTextLayer.kind = LayerKind.TEXT;
newTextLayer.textItem.font = c_CaptionFont;
newTextLayer.textItem.position = [nBorderThickness, nBottomOfFrame + nFontHeight*0.8 + nBorderThickness];
newTextLayer.textItem.size = nFontHeightInPoints;
newTextLayer.textItem.color = colorText;
newTextLayer.textItem.contents = strCaption;
catch (e)
alert(e);
// Restore the background color and ruler units
backgroundColor = oldBackgroundColor;
preferences.rulerUnits = oldRulerUnits;
else
alert("You don't have an image opened. Please open an image before running this script.");
Main();
