Ho una nikon F501 vorrei sapere se posso montare il focusin screen che montava la F301 o se sapete dirmi il pił simile a quello della F301 che posso montare sulla F501.
In rete ho trovato queste informazioni :
http://www.nikonlinks.com/unklbil/screens.htm
e queste :
F501
Focusing Screen Nikon type B clear matte with central focus brackets, 12 mm circle denotes center weighted metering area; changeable with type E or J focusing screens.
Type B: Matte/Fresnel field with 3mm fine-ground matte focusing spot and 12mm reference circle. Good for general photography, especialy with long lenses
Type E: Matte/Fresnel field with 3mm fine-ground matte spot, 12mm reference circle, and etched horizontal and vertical lines. Ideal for architectural photography
Type J: Matte/Fresnel field with central microprism focusing spot and 12mm circle. Good for general photography.
________________________________________________________________________________
F301
Focusing screen
fixed split image screen (K2) with central circle (12mm); The N2020/F501 has interchangeable focusing screens (model B, E or J)
Type K: Combination of Type A and J screens. Matte/Fresnel field with 3mm split-image rangefinder spot surrounded by 1mm-wide microprism doughnut. Rapid and accurate focusing for subjects with both straight lines and ill-defined contours. Suitable for general photography. Standard screen in most manual focus bodies.
Se poi qualcuno ha quello che cerco da vendere meglio ancora
Grazie in anticipo
