QUOTE(larsenio @ Mar 22 2011, 07:45 PM)
Che non c'entra nulla con la fotografia..
come sarebbe a dire....
ma non si è sempre detto che i crt sono meglio degli lcd ???
comunque per qualcuno che ci capisce queste sono le caratteristiche:
Model
CPD-E400
CRT
19" FD Trinitron® with HiDensity™ Electron Gun
Viewable Image Size
18.0"
Aperture Grille Pitch
0.24mm - 0.25mm (variable)
Screen Treatment
High contrast AR Coating
Horizontal Scan Range
30-96kHz
Vertical Scan Range
48-120Hz
Maximum Resolution
1800 x 1440 @ 60Hz
Recommended Resolution
1280 x 1024 @ 85Hz
Factory Preset Resolutions
Timing Data Table (TDT) - 28 modes
User Adjustable - 15 settings
Color Temperature Presets
5000 Kelvin
9300 Kelvin
User-adjustable
sRGB
Signal Inputs
Analog RGB
0.7Vp-p, 75ohm (typical)
External Sync Signals
Separate HD/VD, polarity-free TTL
External Composite, polarity-free TTL
Sync on Green 0.3 p-p±10%, negative
Input Connector
Input 1: D-sub 15HD Captive
Power Requirements
90-264V AC; 50-60Hz
Power Management
International Energy Star, NUTEK,
and VESA DPMS
Operation: <140 watts
Suspend: <15 watts (maximum)
Active Off: <3 watts (maximum)
Power Off: 0 watts
Dimensions (WxHxD)
17.6" x 18.3" x 18.2"
Weight
57.3 lbs
Operating Temperature
50°F-104°F (10°C-40°C)
Operating Humidity
10%-80% (Non-Condensing)
