è da circa 6 mesi che possiedo una nikon D300s acquistata usata, macchina formidabil, tuttavia ho notato fin da subito che le fotografie pare abbiano una grana molto visibile anche a bassi iso (200 / 400).
allego un ingrandimento al 100% di una fotografia, il file NEF non posso caricarlo perche date le dimensioni (20mb) ci metterei un eternità.
preciso che scatto in RAW 12-bit SENZA COMPRESSIONE, controllo immagine SD, d-lightning OFF, NR su pose lunghe off, NR su iso elevati OFF, spazio colore ADOBE.
gli exif della foto sono:
Color Model: RGB
Depth: 16
DPI Height: 72
DPI Width: 72
Orientation: 1 (Normal)
Pixel Height: 2,848
Pixel Width: 4,288
Profile Name: Adobe RGB (1998)
Color Model: RGB
CFA Pattern: 0, 1, 1, 2
Contrast: Normal
Custom Rendered: Normal process
Date Time Digitized: Dec 30, 2012 5:31:03 PM
Date Time Original: Dec 30, 2012 5:31:03 PM
Digital Zoom Ratio: 1
Exposure Bias Value: -0.333
Exposure Mode: Manual exposure
Exposure Program: Manual
Exposure Time: 1/100
File Source: DSC
Flash: Flash fired, compulsory flash mode, return light not detected
FNumber: 7.1
Focal Length: 105
Focal Length In 35mm Film: 157
Gain Control: Low gain up
ISO Speed Ratings: 400
Light Source: Flash
Max Aperture Value: 5
Metering Mode: Pattern
Saturation: Normal
Scene Capture Type: Standard
Scene Type: A directly photographed image
Sensing Method: One-chip color area sensor
Sharpness: Normal
Subject Distance Range: unknown
Sub-second Time: 92
Sub-second Time Digitized: 92
Sub-second Time Original: 92
User Comment:
White Balance: Manual white balance
Focus Distance: 5.623
Focus Mode: 1
Image Number: 16,807
Image Stabilization: 3
Lens Info: 18, 105, 3.5, 5.6
Lens Model: AF-S DX VR Zoom-Nikkor 18-105mm f/3.5-5.6G ED
Flash Setting: NORMAL
Focus Mode: AF-S
ISO Setting: 0, 400
Lens Type: 14
Quality: RAW
Shooting Mode: 1
Shutter Count: 16,807
White Balance Mode: FLASH
Visualizza sul GALLERY : 1 MB
