fgirelli
Main Features
DX Format with 12.4 effective megapixels
The new CMOS image sensor features high image quality and high-speed 4-channel data output
New image processing algorithms combine with optimized analog and digital white balance to produce smoother, more consistent gradations with exceptionally pure color reproduction
Continuous shooting: 3 frames per second (fps) at 12.4 megapixels for up to 10 consecutive NEF (Nikon Electronic Format) images; 5 fps for 18 NEF images at 6.8 megapixels
3D-Color Matrix Metering II with ambient light sensor and 1,005-pixel RGB sensor further improves on Nikon’s acclaimed exposure metering system
High-speed, high-precision 11-area AF system with 9 cross-type AF sensors deliver quick response and sharp focus, even under the most challenging shooting conditions
Two new Adobe RGB color modes further expand professional color space options and also support for sYCC color space
Excellent response with instant power-up and ultra-fast 52ms shutter release lag
Top shutter speed of 1/8,000 second and flash sync speeds up to 1/250 second
Faster read/write speed for the memory card and a USB 2.0 Hi-Speed interface for faster image transfer
Large 2.5-inch LCD monitor for easy access to settings and information, as well as clear, flicker-free image preview
Creative in-camera effects, Image Overlay and Multiple Exposure
Functions such as World Time, automatic rotation of vertical compositions expand possibilities
Lightweight, durable magnesium body
Full support for Nikon's Creative Lighting System when used with the SB-800 or SB-600 Speedlights
In addition to DX Nikkor lenses, the D200 supports more than 50 AF Nikkor lenses
Nikon’s PictureProject software is included, enabling easy control over image adjustment and management
Support for Nikon Capture 4 (version 4.3), a software application with the tools to assist the professional photographer
NEF (RAW) format for the utmost in versatile, effective image control and correction
JPEG and NEF (RAW) Combination Filing System enables simultaneous recording of NEF and JPEG data for the same shot
Specifications
Effective pixels
12.4 million
Image sensor
CMOS sensor, 23.7 x 15.7mm size, 12.84 million total pixels
Image size
Full Image: [L] 4,288 x 2,848-pixel / [M] 3,216 x 2,136-pixel /
[S] 2,144 x 1,424-pixel
High Speed Crop Image: [L] 3,216 x 2,136-pixel / [M] 2,400 x 1,600-pixel /
[S] 1,600 x 1,064-pixel
Sensitivity
ISO equivalency 100 to 800
Storage media
CompactFlash™ (CF) Card (Type I/II) and Microdrive™
LCD monitor
2.5-in., 235,000-dot, low-temp. polysilicon TFT LCD with white LED backlighting
Exposure metering
3D Color Matrix MeteringII , Center-Weighted Metering and Spot Metering
Exposure Modes
Programmed Auto (Flexible Program possible) [P], Shutter-Priority Auto [A], Aperture-Priority Auto [A] and Manual [M]
Interface
USB 2.0 (Hi-Speed)
Power requirements
Rechargeable Li-ion Battery EN-EL3a, Quick Charger MH-18a, AC Adapter EH-5 (optional), Multi-Function Battery Pack MB-D200 (optional)
Dimensions (W x H x D)
Approx. 157.5 x 121 x 85.5mm (6.2 x 4.8 x 3.4 in.)
Weight
Approx. 810g (1 lb 13 oz) without battery and storage media
Specifications are subject to change without any notice or obligation on the part of the manufacturer. August 2005
Franz
Ciao fgirelli,
qual'è la fonte di queste informazioni?
Franz
Fabio Blanco
Io suggerirei di aspettare le comunicazioni ufficiali invece di rastrellare i motori di ricerca in attesa di inutili quanto mai inesatte anteprime inventate. cerotto.gif
marcofranceschini
caro fgirelli
il post che hai aperto è classico da Bar...Sushi...anche se sarebbe da cestino diretto!!!!...non è detto che più tardi....
neanche un commento ti se sprecato a fare , solo un copia ed incolla!!!
marco
mmfr
Pegaso
QUOTE(Fabio Blanco @ Aug 18 2005, 01:43 PM)
xinjia
_Led_
Si, c'è solo una differenza...l'altezza del corpo macchina (e...forse il peso).
Quello che l'ha compilate non ha fatto molto sforzo!
fgirelli
la fonte e dpreview e la pagina da dove era presa sembrava molto una pagina Nikon.
Poi può essere un fake come tanti altri.
mi sembrano un po diverse da quelle della d2x, comunque secondo me manca poco all'annuncio.
Fabrizio
_Led_
QUOTE(fgirelli @ Aug 18 2005, 03:50 PM)
... sembrano un po diverse da quelle della d2x, ...
Fabrizio
nf100
QUOTE(xinjia @ Aug 18 2005, 03:02 PM)
Queste sono fake che girano sul web ormai da mesi... capisco che l'attesa di questo corpo macchina ci rende impazienti ma eviterei di creare discussioni visto che per ora circolano solo voci non ufficiali
Su siate pazienti e non abbiate fretta
@ssembl@tore
Non capisco il motivo di tutta questa fretta hmmm.gif ...se abbiamo dei corpi macchina meravigliosi e altrettanto sono le foto,perche' queste ricerche abissali dove i motori di ricerca fanno fatica ad arrivarci.....ohmy.gif
Con l'uscita della nuova Dxxx non cambiera' il mio modo di fotografare ( schifo faccio adesso e schifo faro' ugualmente dopo laugh.gif )...
Per cui per adesso rimango sulle mie, fino a quando non uscira' qualcosa di stravolgente nel vero senso della parola...poi se invece dobbiamo seguire la tecnologia e' un'altro paio di maniche.. huh.gif
E.A. Juza
Le caratteristiche tecniche citate da fgirelli pare siano apparse brevemente sul sito Nikon Imaging...forse è un altro leak intenzionale in stile D50 (vi ricordate i manuali online un mese prima dell'annuncio?), o forse è solo uno scherzo.
http://alpseb.free.fr/D200/NikonImagingNikonD200.htm
xinjia
lo stesso sito di quelle imagini di prima guardate come prospettava la D50!!!!!!!!
laugh.gif laugh.gif laugh.gif !
xinjia
pare un f55 con la retella di selezione davanti!(che tra l'altro la d50 non'ha)
xinjia
intendevo rotella!
sanvi
tongue.gif Gli eventi di oggi sembrano sovrapporsi a quelli che precedettero l'annuncio della D50. wink.gif
Passi per la D200 di cui se ne parla da una vita, ma la D90 è proprio nuova: che "segmento" andrebbe mai a coprire ?
Vero è che quando è uscita la D50 pochi se l'aspettavano ... booh.
Chi vivrà vedrà !
dakocliff
dry.gif bah, mi par di vedere la stessa ansia di chia compra il telefonino e aspetta subito l'ultimo modello solo per la smania di essere in possesso dell'ultimo grido ed essere hi-tech.
La D200 potrebbe andare su corpo F100 ma la D90....
chi ha costruito questo fotomontaggio non aveva nemmeno idea di cosa stesse facendo!
marcofranceschini
QUOTE(@ssembl@tore @ Aug 18 2005, 04:20 PM)
Ciao Francesco
quindi la D2x non ti ha stravolto!!!!
marco
mmfr
@ssembl@tore
QUOTE(mmfr @ Aug 19 2005, 12:14 AM)
Ciao Francesco
marco
mmfr
-missing
Mah, tutto ciò che ho trovato è un link ad una fantomatica brochure in PDF (che però risulta rimossa). In compenso ho conosciuto il papà della D100, che ha una faccia simpatica e sembra proprio vero.
WAKABAYASHI, Tsutomu
Chief Designer, 2nd Design Section, 1st Development Division, Development Department, Imaging Company, Nikon Corporation
PROFILE:
Born in Shinagawa Ward, Tokyo, in 1956, WAKABAYASHI earned undergraduate and graduate degrees in mechanical physics engineering from the Tokyo Institute of Technology. Joining Nippon Kogaku K.K. (present Nikon Corporation) in 1981, he was assigned to what was then called the Camera Design Group, where he helped design cameras' mechanisms and structures, and contributed to the development of the setting and control indication area.
In 1998, WAKABAYASHI became a development leader for the F80 / N80 and D100.
[attachmentid=24932]
g_max
QUOTE(fgirelli @ Aug 18 2005, 12:33 PM)
Main Features
#CUT#
Mi domando a questo punto...quante D2x pensa di vendere Nikon dopo "questa" D200?
Ma...
Fabio Blanco
QUOTE(g_max @ Aug 19 2005, 09:25 AM)
Main Features
#CUT#
Ma...
Ma Max blink.gif ,
mi lasci un pò stupefatto, scrivi come se ci credessi a questa bufala.
g_max
QUOTE(Fabio Blanco @ Aug 19 2005, 08:38 AM)
Main Features
#CUT#
Ma...
Ma Max blink.gif ,
Era solo una battuta sarcastica, niente di più!
Max
Fabio Blanco
QUOTE(g_max @ Aug 19 2005, 09:45 AM)
Main Features
#CUT#
Ma...
Ma Max blink.gif ,
Max
Meno male Pollice.gif, mi stavo preoccupando per la tua dimostrata capacità di razzocigno laugh.gif laugh.gif laugh.gif
xinjia
Fabio Blanco
QUOTE(Fabio Blanco @ Aug 19 2005, 09:57 AM)
... capacità di razzocigno
Forse sono io quello che sta perdendo qualche colpo. laugh.gif laugh.gif laugh.gif
sanvi
Si stai perdendo lucidità:
fgirelli
A distanza di un giorno pare che in realtà sia un fake.
Comunque ciò non toglie che quest'anno al Photokina qualcosa di nuovo ci sarà di sicuro.
E' impensabile che la d100 vecchia di 3 anni sia ancora in vita.
Altro particolare da tenere conto è questo : d100 in giro nuove non esistono più.
Provate a farvela ordinare..... non otterereste nulla.
Ci sarà un motivo o no????
Fabrizio
Fedro
Fabioooo..... te l'ho detto che non reggi le alte quote....un paio di giri sopra i 2000 e la mancanza di ossigeno ha decimato il tuo vocabolario....
g_max
QUOTE(fgirelli @ Aug 19 2005, 10:16 AM)
Fabrizio
Seguendo il tuo discorso allora potremo ipotecare le caratteristiche della D300, tanto la D200 non resterà in eterno sul mercato!
E perchè no la D3h/x?
E' chiaro che una sostituta della D100 arriverà, su questo non ci sono dubbi, ma non per questo le macchine che abbiamo oggi smetteranno di fare fotografie, e non saranno gli xmega in più o altre balle simili a fare foto migliori!
g_max
QUOTE(Fabio Blanco @ Aug 19 2005, 09:49 AM)
Fabio Blanco
Basta ragazzi mi autosospendo da questo 3D: sto facendo troppi danni alla lingua italiana, ma sopratutto sto facendo una figura di M....
g_max
QUOTE(Fabio Blanco @ Aug 19 2005, 10:39 AM)
Comunque è sempre un piacere leggerti!
Buona giornata
Max
Pegaso
QUOTE(Fabio Blanco @ Aug 19 2005, 10:49 AM)
Confessalo Fabio, il Razzo Cigno (Uccello bianco di considerevoli dimensioni che vola a pelo dell'acqua a velocità non inferiori ai 300 Kmh) è l'incubo delle tue notti: sai benissimo che nemmeno con l'AF di una D2X riusciresti a stargli dietro ...
Hai bisogno di riposo laugh.gif laugh.gif laugh.gif !!!
Angelo
fgirelli
io le foto continuo a farle con la mia d70, però siccome sono appasionato di tecnologia mi interesso anche delle novità sia interne che esterne.
D'altronde mi pare che in questa comunità un sacco di persone sono passate alla d2x , forse perchè le loro macchine precedenti non facevano più belle foto ?
Non credo.
Fabrizio
RAZIOCIGNO: pennuto dal lungo collo che vive nei laghi e in acqua dolce, dotato di una saggezza al di sopra della norma aviaria, da non confondere con Orazio Cigno, personaggio dei fumetti per bambini.
Fabio Blanco
Si si bravi... prendete pure per il cu..
Ma io intanto l'ho fotografato...
Franz
QUOTE(Fabio Blanco @ Aug 19 2005, 02:19 PM)
Franz
Pegaso
Azzz ... blink.gif blink.gif blink.gif ma come hai fatto ?!?!?
Hai una D3Xs in preview ?!?!
marcofranceschini
QUOTE(buzz @ Aug 19 2005, 12:57 PM)
Accidenti tutti amici...perdonali Fabio non sanno quello che fanno...
marco
mmfr
marcofranceschini
QUOTE(Pegaso @ Aug 19 2005, 11:29 AM)
Angelo
Pure io l'ho fotografato con la nuova D200!!!!
e sì ormai la discussione ha assunto le classiche sembianze da...SUSCHI BAR
Max Thorton
Tutto sommato buona parte dei volumi di mercato, sopratutto nei generi voluttuari vengono fatti da segmenti di utenza che smaniano dalla voglia di possedere il meglio del meglio, lo abbiamo visto succedere con la telefonia cellulare, sta succedendo con i televisori al plasma, con i pc portatili ecc. (questo solo per limitarsi all'elettronica di consumo.
Ciò, a mio modo di vedere, si verifica anche in questo nostro amato settore della fotografia. Mi viene da fare una riflessione; se la D2X fosse vendibile solamente a chi possiede pieni requisiti professionali e al contempo ne dimostra una specifica esigenza probabilmente i numeri venduti sarebbero al massimo il 30 % di quel che effettivamente sono ad oggi.
Naturalmente ciò va in prima battuta a beneficio esclusivo delle aziende che producono tali prodotti, in seconda istanza a soddisfazione di quelle fasce di utenza che per sfizio li acquisiscono, ed in ultima analisi ancor maggior beneficio ai summenzionati produttori, che, lusingati da indagini di mercato ampiamente positive, sono dunque spronati a sfornare nuovi modelli che verranno invariabilmente riacquistati dalle ormai note fasce di utenza, nel frattempo nuovamente smaniose di vedere l'arrivo dell'ultimo ritrovato.
è mia opinione quindi che la velocità di uscita di nuovi modelli sia determinata dal mercato, dal suo andamento. Inutile aggiungere da cosa è costituito il mercato.
Non vorrei essere visto come un'eretico o un millantatore ma credo che da qui ad un anno leggeremo insistenti post da parte di persone smaniose di vedere "l'ormai imminente" erede della "D-BLA BLA"
Ci si potrebbero fare sopra mille altre considerazioni ma in questo momento non mi sento in grado.
Max Thorton
